Wiring problems No fuel or spark???
Hi folks, I have searched endlessly to try and find out what the wires are
for on my xr2i 16v engine loom connector.
I have a zvh in it and an ofab loom and ecu.I know what the wires on the
ofab engine loom connector are and what there for but cant find a diagram
telling me about the xr2i 16v side.
I have it wired up colour for colour the now and am getting fuel up to injectors
but no fuel or spark there after.
Any help much appreciated to help me wire this up.Thanks
ive been doing this last night to be fair and on the ofab,ive got 1 earth wire 1 permanent live and 2 switched live to turn the ecu and injectors on does this sound pretty similar to yours,i found if i had one switched live off i wouldnt get a spark or injectors open,also worth checking you have put your switched lives to a permanent switched ie doesnt lose voltage when you crank the engine as this will cut the ecu power when cranking
kosienutter
31
Aug 22, 2015 09:55 AM
Zoggon
Aug 10, 2015 10:39 AM
