instrument cluster
Old May 13, 2011 | 05:23 PM
chad65's Avatar
chad65
Default instrument cluster
hi,has anyone changed the instrument cluster on a transit connect,im having major greif,i changed the cluster for one from a breakers i was told it had to go to ford for reprograming,ford told me yes its £90.....droped the van off phone call of them 3 hrs later..sorry we cant do it it will be £629 for a new cluster as we cant reprogramme a used unit,can enyone shed any light on this....i hate ford main dealers,thanks.
Old May 14, 2011 | 08:08 AM
JonathanJ's Avatar
JonathanJ
The trouble is the way that the cluster is programmed it is meant to be fool proof , so as long as the cluster was programmed correctly from the factory then it can only be re programmed with correct updates , they follow a path and unfortunately it is in most cases a one way path and the IDS searches the chassis no from ecu and then searches the database at Ford for the updates for that chassis , if then it checks the calibration no that is in the cluster and it does not match to one that should be in that vehicle it comes up against a brick wall .
Ford where talking about bringing in a walk around to get around this issue , but I think they realised it would cost them in the way you have discovered , why make it so you can put any used unit in then programme it from a different vehicle when they could sell a new one ....... I know why you say you hate Ford dealers , I worked for one not that long ago and may well be going back there , but sometimes it aint the dealer but what ford instruct them they can and cannot do .
You may find someone can wipe the memory of you cluster but it will not be a Ford place .
Hope this helps.
Old May 14, 2011 | 01:08 PM
chad65's Avatar
chad65
good answer thanks jonathan,you have made it a bit easier to swollow,i have a big mistrust for main dealers,i am a fabricator/engineer so i hate trusting jobs to others.
Sep 28, 2015 10:05 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
Bailes1992
Sep 3, 2015 02:17 PM
BlakeMoyle
Sep 1, 2015 02:24 PM
Old ford
Jul 31, 2015 06:50 AM
