pinto injection wont idle
Old May 7, 2011 | 03:52 PM
brians mk1's Avatar
brians mk1
Default pinto injection wont idle
there is a few have raised this (common) problem but no one has a answer to fix it ..
I rebuilt the engine up after getting it all powder coated, v hard to start and wont idle , cuts out if i dont rev it...
the last time it ran like this i had a split in the induction pipe which was long since replaced..
b4 the rebuild the car was idling at 1900 rpm and if i disconnected the idle sensor then dropped to 1000 rpm
now i can hardly get it to start , runs lumpy back firing .. and cuts out
please help
Old May 7, 2011 | 04:01 PM
JPA's Avatar
JPA
please help
is timing etc ok ? as if it was running ok before rebuild then got to be something you've done ?
might be worth double checking everything
john
Old May 7, 2011 | 04:48 PM
Good advice above, go through everything again, backfiring would point to normally ignition timing out, but there are other causes, valve clearances too tight as well.
Old May 7, 2011 | 05:29 PM
brians mk1's Avatar
brians mk1
timing was doulbe checked , the valves were reground and seated , do you think it is sticking tappets?
Old May 7, 2011 | 06:18 PM
JPA's Avatar
JPA
very unlikely , leads on the right way ? gaps on plugs ? just go through everything step by step it will prob be something silly in the end
john
Old May 10, 2011 | 12:48 PM
brians mk1's Avatar
brians mk1
new plugs
new leads
checked timing , turned anticlockwise about 10deg to get her to start , but still wont idle?
getting good sparks
fuel pump working fine
what about the air flow meter there is an allen key to adjust something???
chowfornow
14
Jan 5, 2019 09:01 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
fordrallycar
Sep 30, 2015 07:57 PM
20/20 vision
Sep 29, 2015 11:27 AM
steff19
Escort Range
Sep 9, 2015 10:14 PM
