whats this?
Old Feb 7, 2005 | 10:04 PM
miltski's Avatar
miltski
Default whats this?
this has broken on a turbo whilst in transit, what is it and can i simply unbolt the torx bolts and replace it?
thank you
[/img]
i'm not talking about the bash on the inlet btw
another pic:
Old Feb 7, 2005 | 10:34 PM
b13nde's Avatar
b13nde
well i would give up its bent the inlet houseing and smashed the
waste gate houseing waste it maybe touching the blades inside
which could break up all go in to your engine leaveing you at
the side of the road with nothing but a pudddle of oil
Old Feb 7, 2005 | 10:37 PM
miltski's Avatar
miltski
its not the wastegate, and the bend on the inlet is only on te lip, the blades move ok
here's another pic:
Old Feb 7, 2005 | 10:41 PM
b13nde's Avatar
b13nde
that is the inlet waste gate yes you can just swap it but they must have dropt it some to dent smash and bend it like that your a brave man putting that on a car
i wouldnt the blades may feel ok but you carnt see every thing and at 100.000
rpm when they say bye thats it game over
Old Feb 7, 2005 | 10:45 PM
miltski's Avatar
miltski
gutted! i bought it on ebay and as i didn't insure for delivery the seller isn't obliged to refund me!!!
cheers for the help anyway
Old Feb 7, 2005 | 11:35 PM
Azrael's Avatar
Azrael
The other broken thing is DV. I don't know where you can get this part for small turbo Cossie though :-(
Old Feb 8, 2005 | 04:12 PM
Andymancos's Avatar
Andymancos
Yup deffo dump valve you can get them from collins or turbosystems there just a bolt on dumper instead of the usual pipe fitting same as the Rover 220 turbo
Old Feb 8, 2005 | 05:02 PM
THE RADMAN's Avatar
THE RADMAN
yes its the dump valve thats smashed to bits,is it a T28?you can either replace it or buy a cold side relocation kit,which should come with a blank to fit in its place
Old Feb 8, 2005 | 05:10 PM
Azrael's Avatar
Azrael
That blank won't fix THIS.
Old Feb 8, 2005 | 05:28 PM
miltski's Avatar
miltski
the turbo is of a rover, i don't want the dump valve why can't i just blank it off?
Old Feb 8, 2005 | 09:23 PM
THE RADMAN's Avatar
THE RADMAN
yes it will! you just remove the knackered dump valve and fit the blanking plate/seal
Old Feb 8, 2005 | 09:26 PM
b13nde's Avatar
b13nde
what about the state of the inlet houseing thats gotta been dropt from the truck and some and abit more for luck
Old Feb 9, 2005 | 06:55 AM
miltski's Avatar
miltski
the inlet housing bash is only on the lip, it doesn't go more than 9mm down, there is still about 20mm left and that is straight.
i might be able to get another housing, but as there is absolutly no play in the impeller, so i think i'll risk it
Old Feb 9, 2005 | 10:05 AM
miltski's Avatar
miltski
just took the cover of the damage to the inlet has not gone far enough definately, and i took the broken pipe bit off the dump valve, although i can get a complete replacement one from collins, so good news!
Old Feb 10, 2005 | 08:57 PM
wilky's Avatar
wilky
Default 620 ti sherpa
the compreser housing look's bigger than a rover
[rover has i think a/r 42 small turbo escort cossy
a/r is.48]i have got a ported commpresser housing
from a rover it had a rs turbo commpresser wheel
in it which is bigger than the rover unit
the other thing to do is blank off the dv with a plate
Old Feb 11, 2005 | 08:56 AM
miltski's Avatar
miltski
done it! machined a plate yesterday and wil hopefully make a tool up today and have a go at annealing the inlet to get it a bit rounder. not too much of a problem if not just have to make sure the inlet pipe is securly on, and i will put a dump valve on the end of the intercooler. problem solved!
Old Feb 11, 2005 | 01:59 PM
wilky's Avatar
wilky
that's what we do to the rover's ,blank them
of and use a different d/v
Old Feb 12, 2005 | 02:27 PM
whitneyd's Avatar
whitneyd
What is that going on?
Old Feb 13, 2005 | 01:22 PM
miltski's Avatar
miltski
my twinky
Old Feb 14, 2005 | 07:26 AM
whitneyd's Avatar
whitneyd
OOOOOKKKKK
