how do you remove cossie fuel feed line?
Old Apr 28, 2011 | 08:53 PM
5tox's Avatar
5tox
Question how do you remove cossie fuel feed line?
Sounds a bit of a dumb question ill admit, but i bought a spare fuel rail for a 2wd saff cosworth (a random ebay moment)
and the plastic fuel feed line had been cut about an inch from the rail,
for the life of me i couldnt see how this pipe pulled away from the fuel rail so
in the end i actually ended up cutting the plastic pipe with a stanley blade.
the plastic pipe did not come away from the rail AT ALL
a bit further down is a round metal (what looks like a one way valve)
with a metal clip on it, when the clip is removed is the whole valve thingy meant to come apart releasing the pipe complete with the union?
if youve ever seen one up close you'll know what i mean, i looked in the manual and it doesnt really say much other than you use special tool number so and so .....
Old Apr 29, 2011 | 07:37 AM
xpackboy's Avatar
xpackboy
get a zip tie cut to the same size as the circumfrence of the rail ,then push into the bulbus part of the rail where the spring sits and haypresto it pops off
Old Apr 29, 2011 | 07:53 AM
5tox's Avatar
5tox
so the round valve thingy with the spring inside comes apart when you put pressure against the spring?
Old Apr 29, 2011 | 07:57 AM
cozzy jeff's Avatar
cozzy jeff
i used this method to release the fuel line from the rail.cut 15mm copper olive through one side so you you can get it over the rail,slide it up into the spring so the spring gets pushed out then simply pull the plastic end and it will come apart.
to remove the plastic pipe from the steel pipe that runs under the car,poke two small screwdrivers into the hole in the black fitting and pull apart a little fiddly but no need for a special tool.
Old Apr 29, 2011 | 08:07 AM
5tox's Avatar
5tox
cheers fellas, the pic really helps too
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Aug 29, 2015 08:16 PM
Bailes1992
Aug 16, 2015 07:14 PM
muffster
Aug 12, 2015 08:14 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
