saff 4x4 std turbo
Old Apr 26, 2011 | 09:20 PM
matcossy's Avatar
matcossy
Default saff 4x4 std turbo
saff 4x4 std turbo with 360 bearing wats the max boost i can run?? and wat sort of power could i get?
Old Apr 27, 2011 | 12:22 AM
Cilly-jey's Avatar
Cilly-jey
i ran 22 psi 4 months and was fine on a complatly standard 4x4 turbo. 27 psi has made it smoke, if that helps u
Old May 2, 2011 | 09:35 AM
matcossy's Avatar
matcossy
yeah thank you for the info just trying to get less lag as my drive to work is a sort twisty roads all way there, wonder if taking the bd14 inlet cam out will help?
Old May 2, 2011 | 09:40 AM
martysmartie's Avatar
martysmartie
More boost won't help the lag, can't really answer the cam question but I don't think it's needed for what you have as you arn't flowing the air to warrent it, it's a common inlet cam choice whilst keeping the standard exhaust cam, so standard inlet may help?
Martin
Old May 2, 2011 | 08:21 PM
Taking the BD14 out will help, but needs the correct chip/map for the cam used.
It really shouldn't be laggy though, should be well on the boost by 3000rpm.
A mapping session can transform the car literally, the off boost esp is totally transformed, mine start boosting by 1400/1500 rpm and full boost by 2500rpm, after it was mapped, and that wasn't the best bit, almost forgot what a petrol station looked like, well not quite but you know what I mean.
Old May 3, 2011 | 07:29 PM
matcossy's Avatar
matcossy
thanks for the replys,, i put £30 of fuel init the other night and got about 30 miles out of it;~{ i think im going to take out the cam and see how i get one...
Matt Baxter
Sep 16, 2015 08:30 PM
frug
Aug 26, 2015 06:46 PM
jaimesdna
Aug 25, 2015 06:59 AM
mrmann
Aug 20, 2015 11:24 PM
IAN RS2k
Aug 18, 2015 07:51 PM
