knock sensor
Old Apr 21, 2011 | 08:18 PM
stevezx6steve's Avatar
stevezx6steve
new guy
Default knock sensor
is it ok to run a s2 erst with out the knock sensor?
im currently changing the rocker cover to a rs1600i and using the inlet to but 1 i need to sort knock sensor and also re locate the charge air temp from which i have welded into the new pipe from i/c to thottle body cheers guys
Old Apr 22, 2011 | 06:47 PM
Not all S2 had knock sensors anyway, I assume yours did, ie your ecu is expecting one ?
I would guess it just deletes ignition retard upon sensing function, so if set up ok should be ok.
Old Apr 23, 2011 | 05:18 PM
stevezx6steve
new guy
cheers mate , it has got a new ecu in it with the colors blue red black is this a knock sensor one or not ?
Old Apr 23, 2011 | 07:38 PM
I'm not familiar with the S2 wiring unfortunately, I would ask stu/msd.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
