pectel t6 ecu
Old Apr 20, 2011 | 07:51 PM
kmustafa's Avatar
kmustafa
Default pectel t6 ecu
hi all. Wondering if someone can help me? My car runs a pectel T6 ecu and currently will not start! Have been advised to check out ecu for fault diagnosis. I need to find somebody close to Derby who has program and and plug in adapter to ECU(9 Pin) or altenatively where I can purchase software and plug in lead so I can do it myself.Any help would be appreciated. Thanks
Old Apr 21, 2011 | 06:40 AM
oldford's Avatar
oldford
Manufacturers website: http://www.cosworth.com/Default.aspx?id=1094933
Old Apr 21, 2011 | 10:16 AM
ian sibbert's Avatar
ian sibbert
Pectel T6 uses a configuration program called Descpro, this allows access into the T6 and lets you look at all the live data. Descpro is readily available and the lead you need to connect to the T6 is a normal RS232 serial lead with a stereo jack plug on the end that terminates into the pectel loom...
The only problem you may encounter is if the ECU is not an 'open developer' unit, this means its linked to a specific tuner or car builder (Msport, MEM, MSD etc etc). If the unit is linked to one of the tuners/builders you may need a 'dongle' to gain access. You will also need to have the correct 'Profile' loaded into the descpro folder for the ECU to be acccessed sucessfully.
If you need 'Descpro' PM your e-mail address and I'll send you a copy, if you need someone to diagnose it i'd probably suggest Harvey Gibbs 01733 576614 or Phil Lanes G & G Motorsport - 07717885420
Old Apr 21, 2011 | 12:13 PM
kmustafa's Avatar
kmustafa
Default Pectel t6
Ian thanks for this vital information.My email address is mm-construction@hotmail.co.uk
Does this program also fault find? Also do you know where I can purchase this lead. My ecu has been programmed specifically for the car by a well known tuner but he is far away and as a last option I will have to trailor the car to him.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
griffo69
Oct 4, 2015 11:58 AM
jay030787
Sep 25, 2015 01:38 AM
Steve Cooper
Sep 15, 2015 04:39 PM
