Inlet manifold spacer
Old Apr 18, 2011 | 06:15 PM
matcossy's Avatar
matcossy
Unhappy Inlet manifold spacer
Hi to all i have just fitted a inlet manifold spacer but now the injectors are at the wrong Angle an the engine is running like crap has any one got any ideas??
Old Apr 18, 2011 | 07:34 PM
xpackboy's Avatar
xpackboy
you need a 17mm spacer from anenbo engineering the rail fits on the oppersite side and the injector are at the same angle as standard, hope this helps
Old Apr 19, 2011 | 06:53 PM
matcossy's Avatar
matcossy
hi the one i have fitted it 20mm.. i think im going to have to mod the rail lugs
Old Apr 20, 2011 | 05:04 PM
xpackboy's Avatar
xpackboy
not if you mill it to 17 mm fit perfect son
Old Apr 20, 2011 | 05:14 PM
Stu @ M Developments's Avatar
PassionFords Creator
Yes, the spacer is too big, it is likely bought from someone who made it out of easily available billet plate instead of machining it to the corerct size, which is more wastefull and thus more expensive for them.
Anyone who wants to avoid this problem should consider buying this one.
Old Apr 20, 2011 | 05:29 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Its 14mm to fit correctly dad .
Old Apr 20, 2011 | 06:57 PM
Mine is 12.37mm and with the cometic gaskets either side fits 100% perfect, most likely nearer 14mm with gaskets, ie the width of the lug, got another 8-10 of them thrown in me garage somewhere, mate made them in his dinner break, all laser cut.
Old Apr 20, 2011 | 08:21 PM
matcossy's Avatar
matcossy
hi,
iv modded the lugs tonight it now fit bang on and its got no running problems, thanks for all your replys..
o i carnt say iv noticed any power gains but it does seem to drive smoother of boost now is this normal?
Old Apr 21, 2011 | 07:57 AM
hi,
Depending on your spec the motor may be running lean and ready to meltdpown. The usually feel lovely just before they explode as the leaner they get the more power they produce... get it checked over for peace of mind mate.
Old Apr 21, 2011 | 10:33 AM
cozmeister's Avatar
cozmeister
More boost Igor!
Such a cruel, cruel irony
Old Apr 24, 2011 | 09:34 PM
matcossy's Avatar
matcossy
thanks for the advice,, if anything its seen to be running rich gray/black smoke now and then
Old Apr 26, 2011 | 07:56 AM
I would expect that OFF boost with a spacer, then lean ON boost.
Nov 1, 2015 06:53 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
mondeomark
Sep 28, 2015 06:28 AM
caprixpack
Sep 25, 2015 07:53 PM
