focus st no compression ....:-(
Old Apr 15, 2011 | 08:48 AM
dbanks's Avatar
dbanks
dbanks.st
Exclamation focus st no compression ....:-(
I own a 57 focus St with 35000 on the clock the engine has no compression :-( any ideas ......????
Old Apr 15, 2011 | 09:20 AM
cozmeister's Avatar
cozmeister
More boost Igor!
No compression on all 5 cylinders?
Old Apr 15, 2011 | 11:51 AM
dbanks's Avatar
dbanks
dbanks.st
That's right I've been told that one of the covers under the car could have shattered and got stuck and knocked my timing out which would cause a lot of damage but they won't know for sure until they take the head off. ..I don't know much about engines my self so am trying to find out iff anyone else has had this problem and can it be repaired or is it a new engine job and what that would cost .....
Old Apr 15, 2011 | 12:39 PM
Sp3no's Avatar
Sp3no
if the timing belt has been disturbed you could be looking at 20 new valves and a head rebuild, you may have got lucky and only bent 10 valves. If you have bent vavles its going to cost over £1000 easily for parts and labour. Either way the head will have to come off.
Old Apr 15, 2011 | 12:43 PM
Ebonycossie4x4's Avatar
Ebonycossie4x4
bend over and lube up your in for a bumpy ride
Old Apr 15, 2011 | 01:06 PM
dbanks's Avatar
dbanks
dbanks.st
Its at Pumabuild at the moment ,there going to let me know on Tuesday ....fingers crossed I. suppose...
Old Apr 15, 2011 | 01:18 PM
chaffe's Avatar
chaffe
Turbocharging Technician
a compression test tells you that you have a problem, but you probably already knew you had a problem! either way the head has to come off, get stripping!
What difference does milage make lol
Old Apr 15, 2011 | 02:28 PM
Sp3no's Avatar
Sp3no
Cor if its at pumabuild add another £1000 to my guestimate
Old Apr 15, 2011 | 04:30 PM
dbanks's Avatar
dbanks
dbanks.st
What do you think it should cost to supply and fit an engine iff that's what I end up having to do....YOUR ADVISE IS APPRECIATED ....
Old Apr 16, 2011 | 06:22 PM
Sp3no's Avatar
Sp3no
EBAY special supply and fit buy it now £1850 lol
Old Apr 16, 2011 | 06:26 PM
Carlos-Titx's Avatar
Carlos-Titx
Ebay and get an RS engine and drop it in. Be cheaper and better performance. Not sure what else would be needed like (ecu etc?)
Old Apr 16, 2011 | 06:34 PM
Danster76's Avatar
Danster76
What a bugger. Not long out of warranty?
TPM961
Jan 15, 2018 10:50 AM
Prickly_buzz
Dec 7, 2017 09:52 PM
IainRS1700T
Sep 25, 2015 06:44 AM
dombanks
Sep 21, 2015 08:38 PM
RS-Rikki
Sep 21, 2015 07:27 AM
