confusing cosworth
Old Apr 13, 2011 | 08:42 PM
TMR's Avatar
TMR
team markku rallying
Red face confusing cosworth
escort cosworth rally car here is the problem. a few days ago it started smoking heavily then cleared after a short blast. was ran again 2 days later and instantly knocked then cleared and came back again intermitantly with varying severity then afer running at tick over for a few minutes dropped a cylinder and wont pick it up again. the suspect cylinder has good spark but with lots of fuel on and all 4 have good compression.????
any help will be much appreciated as we have a rally coming up in a couple of weeks.
also should add it is mapped and running on sunoco racing fuel
Old Apr 14, 2011 | 10:18 AM
Could be a stuck injector, were these cleaned prior to the mapping ?
Try tapping the injector whilst running.
Old Apr 14, 2011 | 12:30 PM
TMR's Avatar
TMR
no they havnt been changed and was only mapped when it was converted to run on the new fuel. will try tapping it when it is running, do the injectors fail in the open position as this would explain the flooding in the one cylinder. also could it need remapping with the change of the turbo and also has recently had a new head fitted. thanks for all the help.
Old Apr 14, 2011 | 05:43 PM
Change of turbo ?, without a doubt it will at the very least need checking fuelling wise, they tend to get sticky and not fully close, or be sluggish in action when gummed up, this can happen esp after a extended period of no use.
Just get them cleaned, then map checked.
Old Apr 15, 2011 | 08:54 AM
TMR's Avatar
TMR
thanks for that it has now started running good after changed all the plugs but still a little worried especialy about the knocking that i was geting. anyone recomend a good mappers or diagnostics for AFRs etc in the yorkshire area
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
