actuators
Old Feb 6, 2005 | 08:46 PM
1tub's Avatar
1tub
Default actuators
what are the max pressures you can run of:-31 and -34
Old Feb 7, 2005 | 06:30 AM
CosRush's Avatar
CosRush
Not sure of max pressures, but with the 'half a hole method' you should have around 7psi with a -31 and around 14psi with a -34.
These can be increased slightly by a tad more preload, probably to around 10psi with the -31 and 18psi with the -34.
You could just keep winding the actuator in until you see the max, but thats not really the way the system is supposed to work. you end up with a harsh wasegate actuation or worse.
The normal way for example is:
If you wanted 20psi for example. You could use a -31 with a tad more preload at 10psi and the BLEED 10psi away, or a -34 with a tad more preload and BLEED 2psi away.
basically you shouldn't be looking to run the max boost over the pressure rating of the actuator itself.
Old Feb 12, 2005 | 07:16 PM
1tub's Avatar
1tub
thanks for that i have a-31 with a dual sbc controller
and i was wondering if i really needed the -34
it would probably be a nicer take up with this one than the -31
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
