Focus Rough Idle 1.8 MK1
Old Apr 7, 2011 | 09:42 PM
Focus333's Avatar
Focus333
Default Focus Rough Idle 1.8 MK1
My 1.8 Focus has had a rough idle for a while now, it seems it wants to stall, but then it revs itself a little to stop it from stalling and repeats over and over, if that makes sence.
I have just today fitted my 2.0 port and polished head with piper cams and vernier pulleys, along with a new inlet manifold and throttle body, cam belts and tensioners, aux belt and tensioners, oil change and filter and thermostat, so near enough a full top end rebuild.
I know the cams will make the idle a bit rougher, but when i 1st start it, its idles nicely for 20-30 seconds...then it starts to go rough.
Im thinking and have read it could be faulty mass airflow sensor or idle controll valve, and to check vacuum hoses and change fuel filter.
The idle controll valve was new with the inlet manifold, so its not that.
Any ideas pleaseeeee help!
Thanks
Joe
Old Apr 7, 2011 | 09:59 PM
hogdog's Avatar
hogdog
Probably the coil pack.
Old Apr 7, 2011 | 10:09 PM
Focus333's Avatar
Focus333
Funny you mensioned that as i just realised this started around the time i replaced it last year and done it ever since....a mate had a new coilpack he didnt need and gave it to me, so i fitted it as it was new, maybe its faulty.
I still have my old one, will fit and try tomorrow, one thing i dont get though if its coilpack, wouldnt i have loss of power too and even one plug not firing?
Thanks
Joe
Old Apr 7, 2011 | 10:27 PM
Focus333's Avatar
Focus333
Even though it was 11 i just went and quickly changed my coilpack over as it was so easy to quickly change and try....still seemed to do it unfortunately.
Think ill try mass airflow sensor next and check the vacuum hoses.
Thanks again
Joe
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Rsmat
63
Sep 25, 2015 12:11 PM
gavt123
Sep 5, 2015 10:03 AM
Fordmad!
Sep 4, 2015 01:42 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
