St170
Old 04-04-2011, 08:14 PM
Jam988
Jam988's Avatar
Default St170
Can someone help me please I have a st 170 and I was on the motorway to London today and my clutch went soft and it was like I could push the clutch through the floor and it comes bk every now and then I looked under the car and there Is signs of a small leakage
Old 04-04-2011, 08:31 PM
JonathanJ
JonathanJ's Avatar
Probably slave cylinder gone , might be caused by release bearing seizing and spinning the piston , but whatever the cause the result is to replace the slave cylinder , and whilst there no matter what replace the clutch whilst there .
Old 04-04-2011, 08:57 PM
Jam988
Jam988's Avatar
Thanks mate it's been playing on my mind all day now I know can I put a race clutch or is it best for a standard one if so Wots the best race clutch to on
Old 04-04-2011, 09:00 PM
JonathanJ
JonathanJ's Avatar
If you are not looking to increase power then a std one will do , heavy duty clutches are ok but in traffic they can be a real pain as they are too heavy , you will have legs like tree trunks
Old 04-04-2011, 10:01 PM
Sp3no
Sp3no's Avatar
the slave cylinder fluid is shared with your brakes so dont let it run low or you will lose all your brakes. Slave cylinder is a gearbox out job so i would definately change the clutch and flywheel whilst your there. I have a stage 3 clutch in my st170 and it drives just as a standard clutch, i never noticed it being any heavier on the foot, well worth the money, cheaper than Ford original equipement too.
Old 05-04-2011, 11:12 AM
Jam988
Jam988's Avatar
Wen u say a stage 3 clutch were did u get it form and wats the full name of it so I can get 1
Old 05-04-2011, 12:43 PM
Sp3no
Sp3no's Avatar
Clutchmasters in the States sell Clutch kits for the ST170 (SVT overthere) and they are rated from stage 1-5 i think, mine is middle of the road kevlar type thats rated to take probably twice as much power as standard. The kit was £600ish and came with Uprated friction plate and uprated cover, Lightweight flywheel and brand new slave cylinder. Ford will want £120+ for the slave cylinder, up to and over £500 for the flywheel and £300+ for the clutch plus fitting.
arkeye
Ford Focus ST
20-02-2016 01:22 PM
Sp3no
27-09-2015 07:23 PM
Marv888
26-09-2015 03:44 PM
Andypandy260
23-09-2015 10:28 PM
pie-face
15-09-2015 10:43 AM
Quick Reply: St170
