Input shaft bearing on T5
Old Apr 3, 2011 | 11:27 PM
chrisa3's Avatar
chrisa3
Default Input shaft bearing on T5
Does anyone know how hard it is to change an inputshaft bearing on a T5 box, ie if it can be done without stripping the whole box. Just recently finished building my Saff but the gearbox is whining on idle and goes quiet when clutch depressed. the car drives mint, changes sweet as a nut and no popping out of gear or crunching.
Ideally wanted to try and drop the box and change the input shaft bearing and front and rear seals before spending £100's on a full rebuild.
Old Apr 4, 2011 | 06:20 PM
Dead easy, take off front bearing carrier, this holds the taper part, this simply prises out, BEWARE there will be a shim behind it, so don't lose it, then the bearing can be pulled from the shaft, it's not a(stupidly) tight fit at all.
Make sure to install shim before new bearing, then use a good sealant around flange of bearing carrier, and also on the 4 bolts that hold the carrier on, make sure the "top" marking is observed on the bearing carrier when refitting.
Old Apr 4, 2011 | 06:37 PM
chrisa3's Avatar
chrisa3
Do you think this could solve the whine, or is issue like to be deeper in the gearbox?
89barto89
Oct 4, 2015 06:59 PM
fordrallycar
Sep 30, 2015 07:57 PM
20/20 vision
Sep 28, 2015 03:03 PM
mondeomark
Sep 28, 2015 06:28 AM
