cossy fuel system help
Old Feb 6, 2005 | 02:18 PM
mcgoo's Avatar
mcgoo
Default cossy fuel system help
right any advice please, i've got fuel at the rail but not through the injectors, theres no fuel at the return hose either, i think it would be unlikely that all 4 injectors would pack up at the same time, so would this mean a faulty regulator?????????????
Old Feb 6, 2005 | 09:31 PM
b13nde's Avatar
b13nde
could be your pump is turning but there no pressure ive had this before
its the last thing you check as you can hear the dam thing buzzing
away take the fuel pipe off and put your finger over the end while some
one swicths the ignition on and see if it will push past your finger it should
do then you will no weather its that just put it in a bucket just so it dont fire it all over you
Old Feb 7, 2005 | 04:18 PM
mcgoo's Avatar
mcgoo
fuel pumps ok, i took the supply hose off and put a container in front and put the ignition on and it shot out really fast
Old Feb 7, 2005 | 09:40 PM
velocity's Avatar
velocity
make sure each injector has a 12v supply with the ignition on,disconnect the injector plug and probe one of the pins in the plug for 12v,if nothing then check for a bad connection at the square connector block on the bulkhead,the heavy red wire into the block is the injector supply,
although unusual for 4 injectors not to opperate,its possible that the ecu is not telling them to open ie giving them an earth in sequence,this as far as i,m aware is controled by the phase sensor in the dizzy,so a good check the phase sensor gap and of all the connections and plugs in this area is recomended,
incidently how do you know the injectors are not opening?are the spark plugs dry,is there no smell of raw fuel from the exhaust,are u sure its not spark related
Old Feb 7, 2005 | 09:51 PM
b13nde's Avatar
b13nde
did you hold your finger over it as it can shot out but have no pressure behind it
Old Feb 8, 2005 | 05:11 PM
boost mad's Avatar
boost mad
u say there is no fuel at the return hoes...... maybe fuel pressure regulator? just an idea
Old Feb 8, 2005 | 06:16 PM
mcgoo's Avatar
mcgoo
thanks for the advice, i will check all these things out and let you know
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
15
Oct 7, 2015 03:43 PM
ginner
13
Aug 30, 2015 08:40 AM
Old ford
Jul 31, 2015 06:50 AM
