over boosting
Old Feb 5, 2005 | 02:39 PM
dean sturgess's Avatar
dean sturgess
Default over boosting
im running a stage 3 saff 4x4 t34,dark greens,big intercooler and now and again it keeps over boosting, its really pissing me off now. what could be causing this to happen please help
Old Feb 5, 2005 | 03:00 PM
Alvyn's Avatar
Alvyn
Default Re: over boosting
[quote="dean sturgess"]im running a stage 3 saff 4x4 t34,dark greens,big intercooler and now and again it keeps over boosting, its really pissing me off now. what could be causing this to happen please help
WHAT are the signs as to you thinking it's over boosting some times, r u sure it's NOT the spark plugs being blown out when under load due to wrong type etc!
only a thought m8
Old Feb 5, 2005 | 05:34 PM
john_p_b's Avatar
john_p_b
i took mine to GGR with exactly the same problem, was solved by adjusting the actuator i believe nothing too major anyway!
Old Feb 5, 2005 | 10:25 PM
nikh667's Avatar
nikh667
Maybe a problem with the amal valve? Perhaps it's intermittantly sticking, causing too much air to be bled off - anyone had trouble with them before? Or a split in one of the thin pipes from turbo, via valve, to actuator? Either of these would cause the actuator to operate at a higher boost pressure than it should. Could be the actuator itself also, split/sticking, therefore not opening wastegate properly.
Old Feb 6, 2005 | 09:18 AM
dean sturgess
normally runs ok peaks around 1.8/1.9 and holds 1.5/1.6bar but the odd time the boost goes around to 2.5 bar which then hits the boost limit plugs are brand new harvey gibbs set the gap and fitted them,also new vacume pipe from amal valve.
Old Feb 6, 2005 | 11:26 AM
Alvyn's Avatar
Alvyn
I WOULDn't want mine boosting @ over 30psi any time on greens so best go and get it checked out! b4 it ends in
Old Feb 6, 2005 | 07:45 PM
nikh667's Avatar
nikh667
Can only really be amal valve, or actuator/wastegate then methinks. Get actuator tested for opening pressure. Check wastegate operating arm is moving freely with actuator rod disconnected. Could also try replacing amal valve with a bleed valve setup, even just to diagnose/eliminate amal valve as the cause.
Old Feb 7, 2005 | 02:33 PM
dean sturgess
well went and had a word with harvey gibbs today,he just told me to turn the boost down one turn
Old Feb 8, 2005 | 03:56 PM
moonstone mike's Avatar
moonstone mike
My 3 door maybe over boosting???? sometimes its as if the whole engine shuts down for a split second is that over boosting???????
Old Feb 8, 2005 | 04:11 PM
Dave Henshall's Avatar
Dave Henshall
sounds like it, but could be a few other things aswell....
Old Feb 11, 2005 | 12:05 PM
moonstone mike
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
