idle valve
Old Feb 4, 2005 | 12:20 PM
Jay,'s Avatar
Jay,
Sponsor
Default idle valve
ive seen a cossie run without on is this easy to do
cheers jay
Old Feb 4, 2005 | 08:17 PM
Dave McB's Avatar
Dave McB
just unplug it.
can be a bit rough starting up when cold tho
Old Feb 4, 2005 | 09:01 PM
Jay,'s Avatar
Jay,
Sponsor
Default yeh but
if i do that it cuts out wonderd wether any of u had done it ]
jay
Old Feb 4, 2005 | 10:14 PM
markk's Avatar
markk
needs base i dle sorting then m8 !
Old Feb 5, 2005 | 08:57 AM
Jay,'s Avatar
Jay,
Sponsor
Default so
it can be done then bae idle is the the large screw under the throttle body.
oh nice 3 door m8 very nice
jay
Old Feb 5, 2005 | 12:29 PM
markk's Avatar
markk
yes the prcedure is to have the car running , iscv plugged in , then unplug ,and set idle speed , it must be done in a certain amount of time , something like 30seconds , then you have to re plug back in and hold the revs for a while , then do it again , cant remeber it all tbh, i dont even have an idle valve
for yours if its stalling i would remove the plug off the iscv, unwind the screww approx 1 turn and see if the car will start and idle , repeat till car will idle, then plug in iscv hold revs ( approx 2000rpm ) let idle , remove plug off valve , no change in revs should occur- base idl ok
all must be done with engine ta normal operatingtemp
Old Feb 5, 2005 | 12:43 PM
Jay,'s Avatar
Jay,
Sponsor
cheers for that and thanks for your time
jay
Old Feb 5, 2005 | 01:07 PM
rapidcossie's Avatar
rapidcossie
can anyone clarify this procedure?
Old Feb 5, 2005 | 01:23 PM
Jay,'s Avatar
Jay,
Sponsor
good call lol
jay
Old Feb 5, 2005 | 01:53 PM
rapidcossie
my car sometimes idels way low?
like 500 rpm then picks itself back up....think the base idle is wrong?
Old Feb 5, 2005 | 01:58 PM
Dilly's Avatar
Dilly
warm the car up, unplug the iscv and set the base idle to 850 rpm. plug the iscv back in and the revs shouldn't move
Old Feb 5, 2005 | 02:16 PM
rapidcossie
trying it now.
Old Feb 5, 2005 | 02:42 PM
rapidcossie
seems to have worked. is this defo not adjusting anything else?
Old Feb 6, 2005 | 05:36 PM
rapidcossie
spoke to ava today nd they confirmed this is the correct way to tune up your idle....how many other cossie are idleing badly and dont how to fix it....give this a try cos mine now idle sweet as a nut just over the thousand!
Nov 1, 2015 06:53 PM
15
Oct 7, 2015 03:43 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
routemaster
Sep 7, 2015 05:27 PM
