tuning a rst s2
Old Feb 3, 2005 | 09:32 PM
powerRSturbo's Avatar
powerRSturbo
Default tuning a rst s2
hi ya can any one help the question is how much would it cost to tune my standard rst to 210bhp+ and what would need to be done any answers i would be greatfull cheers.
Old Feb 3, 2005 | 10:28 PM
AKRS1's Avatar
AKRS1
if you wanna run that much power ideally you would need a stronger engine than standard. How about a uprated intercooler, induction kit, exhaust, chip and a high lift cam. Get it set up right and should see at around the 190bhp mark.
Old Feb 3, 2005 | 10:40 PM
powerRSturbo
cheers mate will take that advice.
Old Feb 4, 2005 | 01:17 AM
bassboy's Avatar
bassboy
hi there...we have built a 230-240hp erst and the spec list was roughly:
1600cc CVH
+.5mm MAHLE pistons with 7.6:1 CR IIRC
burton steel rods
stage 3 turbo with .48 exhaust housing
stage 3 Vulcan engineering head - big valves, fully ported and ported and bench tested
still retaining MFI
EVERYTHING regarding fuelling was renewed - injectors, fuel pump, filter, accumaltor, wiring etc etc
stage 2 bearnie box and 4 paddle clutch (to cope with power)
Pace HUGE front mount intercooler
Pace rad
CVH 34 Kent cam
setup by Ahmed Bayjoo
limitor raised to 7200rpm
runs 22psi boost and lights up the tires in 2nd and 3rd even with the bearnie box in the dry!!
there is NO 5th injector and still on MFI...power figures have been estimated at 230-240hp GENUINE and beats new M3's hands down!
also have a S2 with a ZVH running 230hp
2.1 steel Zetec bottom end
stage 3 turbo
Calibra pistons
stage 3 turbo
stage 3 head
GRS intercooler
Pace rad
FRST OFAB management
custom map by Ahmed Bayjoo
CVH 35 cam (IIRC)
produces 230hp on the dot (cant remember name of RR but was in PF)
bassboy
Old Feb 4, 2005 | 12:26 PM
powerRSturbo
sorted cheers mate would you also recomend a 1900cc convertion with ARP bolts and do you know how much these parts you stated would cost.
Old Feb 5, 2005 | 03:06 PM
sbon's Avatar
sbon
hi mate found ya. Go cosworth cant go wong with cosworth power or if you get an rs turbo has to be S1 get one now and i do the engine for you
Old Feb 5, 2005 | 05:17 PM
powerRSturbo
cosssies blow up mate u know that ha ha ha
Old Feb 6, 2005 | 04:10 PM
sbon's Avatar
sbon
ha ha ha it gets your ass into work in the morning
you should see it now looks cool as
so when you going to get an RS then and let me do the engine you no im GOOD
A.t.p
Oct 23, 2015 07:54 PM
A.t.p
Sep 29, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
`spotty
Sep 25, 2015 11:41 PM
