what could this be?
Old Feb 16, 2011 | 03:01 PM
rhysdavis's Avatar
rhysdavis
Default what could this be?
when my engines cold and i start it it runs fine no problems but when it warms up i get a white smoke coming from my exhaust? anyone no what this could be?
any help would be appreciated
Old Feb 16, 2011 | 03:04 PM
Bailes1992's Avatar
Bailes1992
If it does short journeys then it will be steam in the exhaust burning off.
If it was something serious like a head gasket then it would happen all the time
Old Feb 16, 2011 | 03:06 PM
rhysdavis's Avatar
rhysdavis
i cant actually drive it as i havnt past my test yet haha but everytime i start it, it happens?
Old Feb 16, 2011 | 03:16 PM
performace_ford's Avatar
performace_ford
Nae Bither!
When the car is warm, is there any heat come out the blowers?
Does the temp. guage sit higher than normal?
Also you can check the oil filler cap or water expansion bottle for signs of water mixing with oil (mayoniase).
These would suggest head gasket problems.
But is it smoke or steam? As Bailes says it could just be water lying in the exhaust.
Best of luck!
Old Feb 16, 2011 | 03:20 PM
Bailes1992's Avatar
Bailes1992
Theres your problem. Your doing more damage to your car by starting it up and not driving it.
The car has to be driven to keep the engine from getting full of soot.
When you set fire to something you get water, this water sits in the exhaust and when the engine gets hot it's slowly burning it off.
Stop turning the car on for the time being, change the oil and when you pass your test take it for a good run down the motorway!
Old Feb 16, 2011 | 03:23 PM
rhysdavis's Avatar
rhysdavis
Best of luck!
whats the blowers?
tempature gauge site normally
dont see any signs of water mixing with oil
how could i tell if its smoke or steam?
also my rocker cover gasket had gone, got a new one on the way would that have anything to do with it?
Old Feb 16, 2011 | 03:24 PM
rhysdavis's Avatar
rhysdavis
cheers mate, will do
