mk2 mondeo 2.0 fuel consumption
Old Feb 16, 2011 | 12:04 AM
rob115's Avatar
rob115
Unhappy mk2 mondeo 2.0 fuel consumption
ive got a 2001 mk2 mondeo zetec s and the fuel consuption is really bad 18 mpg its done 160,000 miles not long had it just moted it emissions perfect not leaking fuel has anyone got an idea where all the fuels going thanks rob
Old Feb 16, 2011 | 03:21 PM
performace_ford's Avatar
performace_ford
Nae Bither!
Rob when was it last serviced? A good service usually helps MPG, Is this motorway miles or town driving?
Old Feb 16, 2011 | 03:22 PM
Sp3no's Avatar
Sp3no
Thats shocking!! Pre cat lambda sluggish?
Old Feb 16, 2011 | 03:40 PM
performace_ford
Nae Bither!
Lambda should be fine if it's just been M.O.T'd and the emissions were perfect. I would try new oil, filter, plugs, fuel filter etc. Also try some fuel cleaner through it this usually helps to.
Old Feb 16, 2011 | 06:53 PM
rob115's Avatar
rob115
ok will try good service i think its mainly done town driving ex taxi only thing i can see wrong is temp gauge going up and down plugged laptop in no stored codes or problems hopefully good service sorts it thanks guys
Old Feb 16, 2011 | 07:37 PM
If it were using that much fuel as in burning it, rather than losing it for example, a service is not going to correct the issue, but certainly can't hurt, does it drive ok, no hesitation or anything ?
Old Feb 17, 2011 | 01:18 AM
rob115's Avatar
rob115
it does seem a little bit flat but its done 160000 picks up ok and still goes good after 4000 revs
Old Feb 17, 2011 | 07:50 AM
dojj's Avatar
dojj
Resident Wrestling Legend
2001?
mk2?
it should be a mk3 and i would suspect the flaps in the inlet manifold are causing the problem
do they rattle?
Old Feb 17, 2011 | 07:52 AM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
i've got a 2.0 2000 plate mk2 Mondy and fuel consumption isnt great either, think it could be due a service mind you but i put it down to fuel prices
Old Feb 17, 2011 | 08:15 AM
dojj's Avatar
dojj
mine does about 18 mpg in town and about 34 on the motorway
but it is an auto
i reset all the meters when it went for an mot and when it came out it had done 16 mpg and averaged 1 mph
Old Feb 17, 2011 | 01:18 PM
bigspj's Avatar
bigspj
Originally Posted by dojj
2001?
mk2?
do they rattle?
It is possible, Theres 2 mk2s near me on 51 plates
Old Feb 17, 2011 | 04:38 PM
dojj's Avatar
dojj
Seeing as the mk3 started on an X plate, that just means they've had cars unregistered laying about in a field somewhere
Old Feb 18, 2011 | 08:41 AM
bigspj's Avatar
bigspj
Indeed! My t reg mondeo wasnt registered till 9 months from its build date and my 02 plate fiesta was sat round for 14 months from its build date before being registered. Good call with the flaps in the engine though
Old Feb 18, 2011 | 09:41 AM
northernmonkey's Avatar
northernmonkey
I didn't do it!
Do Mk2's even have the inlet flaps?
I thought they were just MK3 Duratec engines that had them?
You have checked for sticky brake calipers etc?
Old Feb 18, 2011 | 07:07 PM
rob115's Avatar
rob115
dont have flaps on mk2 black top brakes are not sticking on done service today hopefully sorts it or ill have to start selling my arse to pay fuel bills
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
yorkie92
Sep 6, 2015 05:34 PM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
