smoking ??
Old Feb 3, 2005 | 10:10 AM
martinmace's Avatar
martinmace
Default smoking ??
can anyone tell me what the likely problem is here. my saff seems to smoke while easing off the throttle or at junctions. only seems to be for a second or 2 cant really tell if tne smoke is blue or white but it definatley isnt black. doesn,t smoke while driving through the gears up just when slowing down?? any suggestions lads thanks
Old Feb 3, 2005 | 01:34 PM
Alvyn's Avatar
Alvyn
just as a few to point @ bad breathing, worn piston rings,turbo back seal,valve guides,
depending on HOW much it smokes and USAGE of oil Cosworth were designed to use a bit of oil and recommended you check oil DAILY hope this helps
Old Feb 3, 2005 | 04:48 PM
Cossie-Iain's Avatar
Cossie-Iain
Its maybe grey smoke and that could be because your car is running rich and gives you a puff when you back off cos all the fuel aint burnt.Map sensor possibly?
Old Feb 3, 2005 | 04:55 PM
martinmace's Avatar
martinmace
taking the car to jam sport on sat for a set up on the rollers so with any luck they will sort it , if they dont
Old Feb 3, 2005 | 06:32 PM
Cossie-Iain
Good plan let the pro's check it out
Old Feb 4, 2005 | 12:26 PM
martinmace's Avatar
martinmace
i will let you know what happens ... thats if it survives!!!
Steve Escos
Oct 1, 2015 06:57 AM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
A.t.p
Sep 29, 2015 05:04 PM
Brickhouse
Sep 21, 2015 04:31 PM
