focus mk1 double din dvd
Old Feb 10, 2011 | 09:25 AM
focii dan nick's Avatar
focii dan nick
99 focus zetec
Default focus mk1 double din dvd
i want to install a double din touch screen dvd player in my focus, i wnt the factory look with shaved edges ect but to do this i think i have to trim the dash and remove the 4 mounting screws on the dash cover. will the mounting clips (no screws behind radio) hold under driving pressures. any one done this before
Old Feb 21, 2011 | 08:30 PM
focii dan nick
99 focus zetec
you can see some pics on the other page
http://www.fordfocusworld.com/forums...php?f=25&t=962
Old Feb 21, 2011 | 08:41 PM
1223456's Avatar
1223456
not too sure on size, but I would make a replica rectangle frame of the d/din then another around that, place it ocer the existing stereo slot, mark where it is to go then use a d/grinder or dremel to trim away the edges to the frame fits in place. Once in place glass it in securely from the back using tape or moulding plastecine to stop the resin from falling through the front. Once done remove the tape/plastecine and fill with glass from the front, once its gone off sand the profile smooth. If needed glass some flanges in place for the stereo carcase to hold it in place but still make it removable.
Hope this helps
Old Feb 21, 2011 | 09:29 PM
focii dan nick
99 focus zetec
i think i did it a easy way i cut the bezel to cover the new double din as the standard ford radio is slightly smaller, then covered my screen with 5 layers of masking tape all way round. the rubbed wd40 over it so the filler will not stick to the tape. then smoothed the filler to the tape and leave to dry. remove the tape it should pull out easy (because of the oil) and look at the lines around the screen they should all be straight and level. then sand and re-fill where nessesary. my install was harder due to the hazard switch needed lifting and i installed a clock out a mondeo mk3. which needed the dash to be cut.
Old Feb 25, 2011 | 08:23 PM
spanner99's Avatar
spanner99
Have you got any pics?
Old Feb 28, 2011 | 10:49 AM
focii dan nick
99 focus zetec
yea mate ul have to go on a diif forum though, no need to register
http://fordfocusworld.com/forums/vie...hp?f=35&t=1370
S3an
Sep 26, 2015 11:39 PM
JamboRS
28
Sep 14, 2015 09:02 PM
S3an
13
Sep 13, 2015 10:01 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
ST-170
Sep 4, 2015 11:02 AM
