Focus ST 225 xenon headlamp issue
Old Feb 9, 2011 | 10:13 PM
Seriesonersturbowady's Avatar
Default Focus ST 225 xenon headlamp issue
Hi all, not long bought a focus St2 on a 56 plate, having a problem with the dip headlamp aim being on the floor, causing issues at night not being able to see. Have tried adjusting manually and they just re adjust them selves to the floor, they are factory fit xenon headlamps. Car is completely standard including ride height. Any ideas on how to fix would be appreciated. Thanks in advance
Old Feb 10, 2011 | 10:04 AM
Chrissy_bwoy's Avatar
Chrissy_bwoy
Might be an issue with the level sensors in the front o/s and rear n/s arches.
they level the lights according to the ride height, have a play with them and see how you get on.
Old Feb 10, 2011 | 10:13 AM
dojj's Avatar
dojj
Resident Wrestling Legend
you may need to go back to ford to get the alignment sorted if it's got auto alignment
if you disconnect the battery you may need to do this as well, it's all done through the gem and via canbus stuff as far as i can tell as i've had the same issue these past few days on my mondeo, so i simply rewired in manual adjusters
Old Feb 10, 2011 | 10:26 AM
Carlos-Titx's Avatar
Carlos-Titx
Beware if you put in manual adjusters as xenon head lamps have to be self levelling to pass an MOT.
Old Feb 10, 2011 | 06:54 PM
I can't see the mot examiner checking the wiring etc to see who they adjust, especially as it's not in the manual of things to do, if they're adjusted right they pass simple.
Old Feb 10, 2011 | 07:04 PM
Carlos-Titx
When you turn them on they adjust. Beam dips down then auto level.
A good MOT place will check that. If they turn the head lights on and they beam does not move then they fail.
If it is set up as manual adjustment turn lights on, no change of angle = fail.
Old Feb 10, 2011 | 10:54 PM
Ok guys, thanks for your input, checked both level sensors and both working correctly, plugged in snap on scanner, no fault codes and all sensors and motors working correclty, so must be an issue with how they are set, so called up local dealer had no clue as per usual, stuck on IOW so what should i do now? manual adjusters for time being will be a good idea safer than not crashing atm!!! any ideas how to do this?
Old Feb 11, 2011 | 07:54 AM
JonathanJ's Avatar
JonathanJ
Not a very good dealer , you have to use IDS to unlock the adjusters electronically , all it is doing is recovering its "set" position as it sees it , the snap on scanner does not have this option in its menus , think the only one you can use is a IDS , unless there is an update for your scanner online , just a thought .
One cheat you could try is to jack the back end of the car up to kid the system that it is nose down , allow the lights to find their new level then disconnect battery for an hour , drop back end down again and reconnect battery , that would be my only shout without a scanner at hand .
Old Feb 11, 2011 | 09:57 PM
ok jon thanks for the advice, will make sure i try the fall the lamp level sensor first, sounds a little crude but worth a try, did call FORD TECHNICAL on there Ł1.00 a min line, they had no idea either which was dissapointing. Thanks for the reply though
Old Feb 12, 2011 | 06:40 AM
JonathanJ's Avatar
JonathanJ
Will try and get the correct procedure on Monday from a friendly dealership , I used to be technical service foreman there but cannot remember for the life of me , other than IDS must be used , the exact order
Old Mar 19, 2017 | 08:30 PM
Jlroberts's Avatar
Jlroberts
I'm having this problem now, please tell me the original poster is still on here and knows the fix!!
Old Aug 3, 2017 | 08:38 AM
minesy2010's Avatar
minesy2010
hello i have a focus st225 and when putting my foot down im getting a hissing noise. ive checked for boost leaked and i dont think its that because this noise can be there 1 min and then wont be there for 10 mins and runs fine and then it will be back again could any1 help cheers
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
gingeRS
Sep 4, 2015 06:29 PM
Sep 3, 2015 10:49 AM
