PF09 Throttle position sensor - how to set?
Old Feb 7, 2011 | 07:30 PM
2wd_tec's Avatar
2wd_tec
Default PF09 Throttle position sensor - how to set?
Hi all
i have fitted a PF09 tps to my 2wd cossy along with a l8 ecu e.t.c
i was wondering could someone please expain to me in detail how to go about setting it perfectly. I have swapped the two outer wires on the tps plug, just need to know how to get it set up right.
thanks shane
Old Feb 8, 2011 | 07:09 AM
oldford's Avatar
oldford
Measure voltage and set to 0,15 - 0.20V at idle.
Old Feb 8, 2011 | 12:51 PM
2wd_tec's Avatar
2wd_tec
Thanks for reply. How do I measure this, where do I put the multimetre pins? And also if the value is not what
I want how do I adjust to suit? Sorry but I'm a novice in all this
Old Feb 8, 2011 | 12:54 PM
JamesH's Avatar
JamesH
To adjust it loosen the two small allen key bolts and swivel back and forwards with the throttle cable attached, you'll see your voltage move
Can't remember the ECU pins sorry
hopper350
Sep 4, 2015 12:53 AM
Bailes1992
Sep 3, 2015 02:17 PM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
Cragrat
Sep 2, 2015 08:25 PM
