Temp Gauge
Old Feb 4, 2011 | 09:48 AM
Thomasw's Avatar
Thomasw
Default Temp Gauge
Hey
Any advice will be great
After 7 attempts of my car going back to the garage my temp gauge still seem to go into the red The garage have said they have replaced the sensor, even put in a brand new gauge, still it remains to go into the red, While driving the car this morning i noticed the car was warm inside (heater) even tho the dials where on the blue(cold) hmmmmm
thanks
Wthomas
Old Feb 6, 2011 | 06:46 PM
Churtz's Avatar
Churtz
hi.
Neeed some info on the car? model and engine size etc.
matt
Old Feb 6, 2011 | 06:51 PM
martysmartie's Avatar
martysmartie
Perhaps it actually is overheating, maybe a faulty stat I.E stuck closed one minute (The overheating) and open the next hence the gauge showing lower and heaters working?
Martin
Old Feb 7, 2011 | 12:05 PM
Thomasw's Avatar
Thomasw
Hey There
Car gone back in again this morning
car - ford fiesta 1.6 zetec 2000 wreg
Something tells me the head gasket has gone and the garage are in dinial???
thanks
wthomas
Old Feb 7, 2011 | 12:48 PM
martysmartie
Check your coolant level...
Martin
Old Feb 7, 2011 | 02:49 PM
JonathanJ's Avatar
JonathanJ
Air lock in cooling system ?
Old Feb 7, 2011 | 03:12 PM
bythomson's Avatar
bythomson
another garage for a second opinion,
Old Feb 7, 2011 | 07:50 PM
Churtz's Avatar
Churtz
by "dials in the blue" i presume you mean the heater control dial? This sounds like a classic example of the very common heater control valve (HCV) failure. They fail so often its untrue, and the last one that failed on me casued a blockage in the coolant flow - meaning overheated. It falls in line with what your saying too, as it controls the coolant flow into the heater matrix - so if it was messing around when ur telling it to be cold in the car it was opening and malking it hot in the car.....
Matt
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
