help please!!!!!!!fan and heater!
Old Jan 16, 2011 | 01:32 AM
emskinem's Avatar
emskinem
Default help please!!!!!!!fan and heater!
hi there experts!yesterday morning i used my car and the heater and fan is working. after that i went home and rest, then on the afternoon when iwas going to my work i dont have a fan and heater, what do you think is the problem, im here in edmonton canada and its freezing cold right now thats why heater is very important. thank you all!
Old Jan 16, 2011 | 02:06 AM
botters's Avatar
botters
competant bodger
what vehicle? most common cause for many a vehicle is the heater risistor
Old Jan 16, 2011 | 10:13 AM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
as above,
Old Jan 16, 2011 | 08:40 PM
martysmartie's Avatar
martysmartie
If it does not work on any setting I would suspect a power/motor problem, start by checking fuse etc. If it works on the top setting then suspect resistor pack, I am assuming a Ford here!
Martin
Old Jan 16, 2011 | 08:46 PM
emskinem's Avatar
emskinem
your right martysmartie. its a ford focus. i dont know where is the fuse and resistor pack, i am a rookie on this matter.thank you mister martin for your reply.
Old Jan 16, 2011 | 08:51 PM
martysmartie
Fuse 64 (30A) in the engine compartment is the fuse (MK1). You need to determine if it works on any speed at all, if it works on Pos 4 then it will be the resistor pack, if you have nothing at all suspect a power/motor problem.
Martin
Old Jan 16, 2011 | 09:58 PM
emskinem's Avatar
emskinem
mr. martin thank you for your time, is it the fuse 64(30A)? because our
air con is not working too. and also our heater and fan?thank you mister!
Old Jan 16, 2011 | 10:10 PM
emskinem's Avatar
emskinem
i tried to put on the fuse for abs thats also 30 A but it still doesnt work, maybe its not the fuse, i dont know, waaaaaaaaaaaaaa!thanks guys for helping.
Old Jan 16, 2011 | 10:14 PM
emskinem's Avatar
emskinem
guys its a ford focus 2000 model, i tried to put on a working fuse on fuse 64 and its still doesnt work, i dont know, how about a resistor,i dont know what to do with that.help please!!!!!!!!!
Old Jan 17, 2011 | 09:05 AM
martysmartie
I would next be looking at the switch...
Martin
Old Jan 19, 2011 | 06:11 AM
emskinem's Avatar
emskinem
martin your really good on this matter,yes its the switch, i already hire an technician on this matter and its the switch, they said its freezes, they charge me 179 canadian dollars, but thats alright, thanks once again, your a nice guy,thank you. can i add you as a friend in here?
Old Jan 19, 2011 | 12:27 PM
martysmartie
No problem glad it's sorted, request accepted
Martin
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
Flatlinedan
Sep 18, 2015 12:41 PM
