cutting bump stops
Old Jan 14, 2011 | 06:17 PM
chris m1's Avatar
chris m1
Default cutting bump stops
just picked up a new Gmax kit and it says to trim the bumpstops by 200mm (20cm in old money lol).. Is this the case or just ignore it and fit them straight up?..
Mk4 escort btw
Old Jan 14, 2011 | 06:53 PM
JonathanJ's Avatar
JonathanJ
20 mm would be more like it
Old Jan 14, 2011 | 09:33 PM
chris m1's Avatar
chris m1
thts it.. to mamy 0's lol
Old Jan 14, 2011 | 10:01 PM
RichieST's Avatar
RichieST
I have personally never bothered on all my cars and have not had a problem. However if the kit says to do it, you don't and crash and die, then at least GMAX won't be responsible
Old Jan 14, 2011 | 10:29 PM
chris m1's Avatar
chris m1
i hadnt planned on the second part anyway, so what hell lets bung em on
Old Jan 14, 2011 | 11:45 PM
am4nf's Avatar
am4nf
Ive only ever heard of cutting the bump stops to make the car lower......
Old Jan 15, 2011 | 12:35 AM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
bump stops in them selfs will not make a car any lower..
Old Jan 15, 2011 | 09:26 AM
am4nf's Avatar
am4nf
Surely on coilovers wound all the way to sitting on the bumpstops, cutting them would make it lower? or able to go lower...
Old Jan 15, 2011 | 09:54 AM
JonathanJ's Avatar
JonathanJ
We have to remember that the body of the damper maybe 20mm longer so cutting the bump stop 20mm will only really allow the wheel to move to the same point in its travel as it would normally , just a thought
Old Jan 15, 2011 | 03:11 PM
xrmalin's Avatar
xrmalin
My mate fitted a set of g-max shock and springs to his ecsort gti and in the instructions it said to trim the bumpstops but he didnt bother and a week later they were smashed to bits and he had to fit new ones
mark.
Old Jan 15, 2011 | 04:11 PM
chris m1's Avatar
chris m1
So cut/dont cut??..If cut what part of the stop gets cut?.
Old Jan 15, 2011 | 04:23 PM
clarke5700's Avatar
clarke5700
yes with COILOVERS they wound prevent the car from going lower. but as i said "bupmstops in them selfs will not lower a car"
Old Jan 15, 2011 | 04:28 PM
taz1787's Avatar
taz1787
Escort Cabriolet Owner
no but surely if they are a standard bumpstops and lowered sus? then they would stop it lowering to its full potential?
also chris if cutting then i would cut base down
Old Jan 15, 2011 | 04:42 PM
chris m1's Avatar
chris m1
right its this kit and its going on a 4door mk4
http://www.gmaxsuspension.co.uk/gmax...2_p1250597.htm
Old Jan 15, 2011 | 05:07 PM
taz1787's Avatar
taz1787
well you may not need to cut them chris as your car standard suspension is softer then a rs turbo standard suspension in the first place
Old Jan 15, 2011 | 05:15 PM
chris m1's Avatar
chris m1
Well ive got a set of spare stops so will dig out the siccorss and have a play.. failing that they'll be up for sale midweek lol
Old Jan 15, 2011 | 06:16 PM
JonathanJ's Avatar
JonathanJ
Whenever I have cut bumpstops , always cut the solid end , as the other end is shaped to produce a rising rate as it is compressed therefore not being a solid stop so to speak .
Old Jan 15, 2011 | 06:25 PM
chris m1's Avatar
chris m1
would poly bushes do the job oppose to cutting the originals?
Old Jan 15, 2011 | 07:28 PM
JonathanJ's Avatar
JonathanJ
if poly bush do the bump stops you might still need to cut them so the length is correct for the body length and the required wheel position when the bump stops start to come into effect .
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
Fudgey
21
Sep 30, 2015 06:19 PM
