xr3i efi co2 pot
Old Jan 13, 2011 | 08:27 PM
brianL84's Avatar
brianL84
Default xr3i efi co2 pot
hi can anyone tell me the resistance of the co2 pot as mine is dun in and need to replace it if i can find out the resistance i can go to maplan and buy a potentiometer with the same resistance thanks
Old Jan 13, 2011 | 09:41 PM
brianL84's Avatar
brianL84
surly some one must no can nobody help me here
Old Jan 14, 2011 | 10:44 AM
JonathanJ's Avatar
JonathanJ
Ok , sorry for slow reply , missed this yesterday , I have a spare one that is off a FRST so measured this it has readings of 0.47 K ohm to 5.79 K ohm measured between pins 2 and 3 , mine was set at 3.75 K ohms so if stuck you might get away with one between 3 and 4 just as a thought .
Hope this helps
Old Jan 14, 2011 | 11:34 AM
brianL84's Avatar
brianL84
brilliant mate thank you very much
Old Sep 28, 2018 | 11:20 AM
TonyKnife's Avatar
TonyKnife
In case anyone else lands here, like I did, in the search for CO2 pot answers, I have a little more information:
The bottom panel can be removed, and the pot is actually a 43P502 - 0 to 5k, originally made by Spectrol (now Vishay)
Pins 1 and 3 (the outer pins) both have a 470ohm resistor on, taking the range from 470 to 5k4.
The part to replace the potentiometer can be found on Mouser or eBay easy enough - if you're handy with a soldering iron, its an easy enough job for a couple of quid of materials!
There are 2 of these parts (Ford: 082926) on ebay at the moment for £35 and £91 (yes that is a 9 and a 1!)
If you have a broken one you want to fix, I can put up instructions and photos and stuff, but what I'm seeing is the value is in the housing, so don't chuck it
Old Sep 28, 2018 | 11:32 AM
haz87's Avatar
haz87
7yr old post - hopefully he sorted it
Edit: good info tho!!
Old Mar 27, 2020 | 09:02 PM
Charlsieduke's Avatar
Charlsieduke
Default Landed here
help im stuck i have gunson fault codes 053 059
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
