chip imformation.
Old Jan 10, 2011 | 09:20 PM
cossie.087's Avatar
cossie.087
Default chip imformation.
hi can someone tell me if this chip is stage 3,its off my old engine the lad i bought the car from didnt know what was in it.http://the second one is the one iam running now was said to be stage 3 but i dont know the picture is bad but i think this is what is on the chip.
sue collins
stratecy
4x4 1a
checksum
353f
injectors
plgn
jml
this is writen in ink and hard to read so could be all wrong.any help welcome thanks cossie.087.http://
Old Jan 10, 2011 | 09:23 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
It has a sticker that implies
Level 8 ECU
T34 Turbo
Green injectors.
Wether it actually is or not though, is anyones guess of course!
Old Jan 10, 2011 | 09:46 PM
cossie.087's Avatar
cossie.087
thanks chip any idea what the second one is.
Old Jan 10, 2011 | 09:48 PM
Chip's Avatar
Chip
No mate, Im not familiar with how collins name their chips
Old Jan 10, 2011 | 10:07 PM
cossie.087's Avatar
cossie.087
thanks anyway chip.i changed over ecus and the one with the t34 chip in it starts and runs fine but as soon i hit 4000 rpm it would back off hard a real neck breaker dose a chip have to be mapped to suit a specific turbo, if so could this mean iam not running a t34.
Old Jan 11, 2011 | 11:20 AM
Chip needs to be mapped/written to suit every aspect of the engine that affects flow, so esp so in the case of a turbo change.
Old Jan 11, 2011 | 11:30 AM
Chip's Avatar
Chip
Stop what you are doing right now mate, and get it to a tuner, you'll end up melting your engine if you carry on and YB's are getting dear to replace!
Old Jan 11, 2011 | 12:31 PM
martysmartie's Avatar
martysmartie
It's deffo an L8 I can tell that by the circuitry, Sue Collins runs Collins performance with her son Martin. Get a tuner to examine the map would be the easiest way, company's like MSD keep a S/N based record of all there chips so you could of just phoned them with the S/N and they would have been able to confirm but in other cases this is not possible.
Just because it starts up and runs does NOT mean it's the correct chip, the turbo housing is critical to the software, I.E a T34 with .48 housing and .55 would require different calibrations. You need to get that chip confirmed and get it to a tuner to get the fueling etc checked out.
Re the second check 353F I am pretty sure is the check sum algorithm used.
T34 is a hybrid uprated turbo which is what most stage 3 conversions consist so most likely you have (BT Escos has same turbo but with the largest exhaust housing (.63) T3 is standard turbo on these.
Martin
Old Jan 11, 2011 | 08:00 PM
cossie.087's Avatar
cossie.087
Martin
thanks for your advise guys.i will change back so its sounds like my old engine could have been running at at34.
Old Jan 11, 2011 | 08:13 PM
martysmartie
Probably still is (It would have be silly to downgrade again) upgrading the turbo is a done thing when tuning as the T3 starts to run out of puff.
Martin
Old Jan 11, 2011 | 08:37 PM
cossie.087's Avatar
cossie.087
i still have my old engine and turbo so it would be worth while bringing turbo and ecu with me to the tunners when i get the time its along way for me to travel to msd.
tankybaby66
Feb 6, 2016 02:24 PM
Fiddy
21
Sep 29, 2015 06:10 PM
A.t.p
Sep 29, 2015 05:04 PM
RSmark84
Sep 13, 2015 01:29 PM
