not turning over
Old Jan 31, 2005 | 05:25 PM
sime73's Avatar
sime73
Default not turning over
had a prob with the water in the fusebox on my mk6 scort so took it out and cleaned it all up. put it back in and the car would not turn over, it does everything leading up to turning the key, ignition on, pump primes but no turnover
i changed the fusebox for another one just in case i had done something, charged the battery but its still the same
any ideas ?
Old Jan 31, 2005 | 07:18 PM
wayniac's Avatar
wayniac
does the startermotor click at all ? try a live wire right from the battery to the starter make sure it aint in gear tho eh
and make sure you get the right connector on the starter with the temp wire.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
A.t.p
Oct 23, 2015 07:54 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
rsguy
44
Sep 29, 2015 03:29 PM
