brakes
Old Jan 1, 2011 | 04:25 PM
burnhamshaun's Avatar
burnhamshaun
Question brakes
fitted cossy brakes today only thing is i now have to push the pedal 3 quarters down before i get any resistance from the brakes then when they do start working theres not really much there be for we change the brakes the brakes would start working at say 1/3rd of the pedal been pushed down has something been down wrong brakes were bled using an automatic bleed kit
Old Jan 1, 2011 | 08:24 PM
burnhamshaun
could it be that the engine was not running whilst doing this as i just read on another forum that you should have your engine running when bleeding the brakes
Old Jan 4, 2011 | 07:57 PM
burnhamshaun
also what size bleed nipples are these as i want to replace them any ideas peeps
Old Jan 6, 2011 | 07:48 PM
burnhamshaun
Help please guys
Old Jan 8, 2011 | 05:04 PM
Spammage's Avatar
Spammage
I dunno if the engine running has anything to do with it. But make sure there's enough fluid in the resivoir and bleed them again sounds like you've got air in the system.
Old Jan 9, 2011 | 12:51 PM
DirtyPykey's Avatar
DirtyPykey
Motorsport Level 3 Studen
Im not sure but i think having the engine on when bleeding the brakes will help as this will make the servo work.. check the resevoir level
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
