escort van doesnt start
Old Dec 20, 2010 | 12:52 PM
Markt8's Avatar
Markt8
Default escort van doesnt start
hi guys i have an escort van x reg 1.8 non turbo diesel, it was a great starter until i let my friend start it, it started and conked out, ever since it hasnt started, it will tow start and im getting diesel to the injectors when cracking off the injector pipes, ive tested all the glow plugs individually and there glowing but i dont seem to have power to them,im getting the glow plug relay click, i have tried putting a wire to the 8mm bolt at the start of the glow plugs from the battery and holding the glow plug onto the engine this heated up the plug so im guessing the wires are ok on the plugs, anyone any ideas it was fine and this suddenly happened
mark
Old Dec 20, 2010 | 01:59 PM
Markt8's Avatar
Markt8
now have power to my glow plugs fuse was popped but got a flat battery now so we'l see what happens
mark
Old Dec 20, 2010 | 02:47 PM
r06ert's Avatar
r06ert
took me half hour to get mine started saturday, hasnt run for a week and the primary pump has a push value on the top, which i kept on pushing three times and then try starting again, while jumping of another car. the glow plugs arent great and am looking to replace, but the pump was my problem in the end and had been in the past
Old Dec 20, 2010 | 03:50 PM
Markt8's Avatar
Markt8
mines always been ok until just that day, my push valve keeps going soft dunno if this is normal? ive got power to the glow plugs but it doesnt start sill just cranks getting fed up with it now, if i tow start it then its spot on, even starts up straight away when warm just refuses to from cold
mark
Old Dec 20, 2010 | 04:28 PM
martysmartie's Avatar
martysmartie
Is the battery in good condition/charged? An engine is hardest to start when cold, leave alone in these conditions and so the battery needs to be in good condition so the starter and the glow plugs get the power they need. A weak battery will be shown in the cold weather due to the extra demand on the electrical system.
Martin
Old Dec 20, 2010 | 04:52 PM
Markt8's Avatar
Markt8
Got 2 100 batterys that I keep charging to try and start it so batterys are ok but it doesn't take long to flatten them
Old Dec 20, 2010 | 07:43 PM
martysmartie
Then either the charging system isn't performing correctly, you have a drain, or the battery's arn't any good hence unable to hold charge, the former is more likely.
Martin
Old Dec 20, 2010 | 08:17 PM
Markt8's Avatar
Markt8
Martin
Hi batterys are fine, it only drains them from starting it so much one is a 1yr old battery
Old Dec 20, 2010 | 08:23 PM
martysmartie
Oh thats fair enough then, have you tried renewing the glow plugs?
Martin
Old Dec 20, 2010 | 11:20 PM
Markt8's Avatar
Markt8
no might be the next option, they do glow though have tested them
mark
Old Dec 22, 2010 | 01:18 PM
Markt8's Avatar
Markt8
Took my fuel filter pipes off and got no diesel in the pipes to the pump, bought a one way pump/valve and i got the diesel back to the pump but got a flat battery now so im hoping it starts up when i get the battery charged up
mark
Vincereese
Jun 1, 2023 09:14 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
druidgetafix
Aug 15, 2015 10:22 AM
vdubo7
Aug 2, 2015 08:17 PM
