cossie over fueling too much
Old Nov 25, 2010 | 05:12 PM
cossie789's Avatar
cossie789
Unhappy cossie over fueling too much
hi
i have a sierra sapp cossie recplica engine was running well when it was on the other car now its over fueling too much .any hint with this? please
don't know i sure i made all the wiring good the olly plug that i didint find where to plug it is a white plug intake manifold side near the gearbox side does it have something to do with this?
10x rick
Old Nov 25, 2010 | 05:21 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
What engine helps
Steve
Old Nov 25, 2010 | 06:13 PM
cossie789's Avatar
cossie789
hmm ok cosworth 205 block of an 89 sierra sapp cosworth this helps ?
Old Nov 26, 2010 | 04:03 PM
stickertone's Avatar
stickertone
are you running a cossie loom???? temp sensors etc???
Old Nov 26, 2010 | 04:12 PM
If the white plug goes to the distributor so you don't have the phase signal it will over fuel massively.
The plug that goes to the side of the intake plenum is brown for the air temp sensor.
I would if it's not new fit a new coolant temp sensor, at rear of head below inlet, a blue sensor, next to a 1/2" water pipe.
Old Nov 26, 2010 | 07:56 PM
cossie789's Avatar
cossie789
yeah cossie loom (webber ecu) the plug in at the rear not near the distributor , the distibutor plug is connected ok i tried it on 1 bar fuel pressure and still the same 10x for helping btw
Old Nov 28, 2010 | 10:40 AM
martysmartie's Avatar
martysmartie
Check the MAP sensor pipe is A) connected and B) not split.
Martin
Old Dec 1, 2010 | 07:25 PM
cossie789's Avatar
cossie789
mechanic told me fuel pump relay anyone knows where it is?10x
rick
Old Dec 2, 2010 | 09:31 AM
martysmartie
LOl what the fuel pump relay causing over fuelling? If the car runs fine there is no need to touch the fuel pump relay.
Have you had the fuel pressure checked?
Martin
Old Dec 2, 2010 | 06:02 PM
cossie789's Avatar
cossie789
fuel presure is 3 bar. relay he said is like a regulator . when the engine is running idle it will send less fuel ..... the engine is over fueling badly that it wil need to take plugs out to restart bores get flooded hope this helps
Old Dec 2, 2010 | 07:40 PM
wes's Avatar
wes
Hmm wouldn't let that mechanic near my car! Fuel pump relay is switched on/off by the ecu (pin 28), it doesn't send a variable voltage to it, it simply earths the relay.
Is your tps connected? Or as mentioned above the ect sensor (blue) might need replacing or plug to it maybe faulty, if the ecu doesn't detect ect signal it will overfuel as it thinks it's cold so pumps extra fuel in.
Old Dec 2, 2010 | 07:51 PM
cossie789's Avatar
cossie789
it dose it when its cold it starts only ones revs idel about 1500rmp i connected the tps and still the same
Old Dec 2, 2010 | 08:07 PM
capriturbo's Avatar
capriturbo
Have you got the ICV and Cylinder 1 Injector plug the right way around? There both white and easy to get mixed up, I've done it several times!
Old Dec 2, 2010 | 09:24 PM
martysmartie
He actually talking about the regulator this is a mechanical device and the only thing that can vary fuel pressure, you can see this if you look underneath the bonnet, it sits between the fuel feed and the injector rail. It increases the fuel at a 1:1 ratio.
Martin
Old Dec 3, 2010 | 04:39 PM
cossie789's Avatar
cossie789
fuel pressure regulator ........ that is set at 3 bar i tried to drop it 1 bar but still the same
Old Dec 3, 2010 | 04:43 PM
COLEYST200's Avatar
COLEYST200
the blue plug at the right side back its a water tep censer for the ECU try a new one in there they are only cheap
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
Cossiesteve
Ford Escort RS Cosworth
Sep 17, 2015 12:37 PM
kevin36
Sep 8, 2015 12:23 PM
Thanasis
Sep 7, 2015 07:33 PM
