RST Fuel gauge
Old Nov 23, 2010 | 01:10 PM
Jonnie_d's Avatar
Jonnie_d
Default RST Fuel gauge
Hi all,
My Orion turbo has never had a working fuel gauge it reads empty when full and 1/2 tank when empty!
I have Orion EFi wiring with an MFI tank and pump, i have played with the wiring more times than i car to imagine and have tried new clocks. The only thing i havent tried is the sender.
What do you rekon?
Many thanks in advance
Old Nov 23, 2010 | 05:52 PM
martysmartie's Avatar
martysmartie
Should think it's a sender problem, it's basically reading in reverse (I.E Wrong polarity) and not right as it's showing a wrong reading on a full tank.
Earth the sender wire as a test, the gauge should then read full, if so then it confirms it to be the sender.
Martin
Old Nov 24, 2010 | 08:04 AM
Jonnie_d's Avatar
Jonnie_d
Ah Martin you Gentleman, thank you very much. I do remember when trying to get it to work before, if i earthed the wire as you say, it did indeed read full!
Thanks again
Old Nov 26, 2010 | 12:43 PM
martysmartie
No problem, glad I could help.
Martin
JK12
33
Apr 26, 2021 12:09 PM
Chas
Oct 5, 2015 07:13 PM
A.t.p
Sep 29, 2015 05:04 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Billy_RS
Sep 13, 2015 04:17 PM
