New owner and have a problem, ST170
Old Nov 22, 2010 | 08:42 PM
ray170's Avatar
ray170
Default New owner and have a problem, ST170
hi new to site got a st170 brill car management light came on had check done cat nak fit new 1 light came on 3000 miles later went to a garage and got it plugged in not much to go on reset light came back on day later done self test with igniton on and mile button came back with p117 code fan sensor .gave aboot full last night light went out working fine now anybody now how this occured thanks
Old Nov 23, 2010 | 12:35 AM
JamesyRS's Avatar
JamesyRS
dodgy wire/connection to sensor that code is for?
Old Nov 23, 2010 | 06:13 AM
oldford's Avatar
oldford
If you mean the code is P0117 then - Engine Coolant Temperature Sensor 1 Circuit Low
Otherwise look up the description here: http://www.dtcsearch.com/
Old Nov 23, 2010 | 08:09 PM
ray170's Avatar
ray170
yep thats the code i have found and the thats what ive been told it is, i thought that once the code has been logged then you would have to reset the light but if it is a loose connection and is now ok that would explain the light going off.
Cheers!
Old Nov 25, 2010 | 03:46 PM
mobb-black's Avatar
mobb-black
I had an st170 for a couple of years and the ECU lights are forever coming on, not sure why it just seems to be a common fault with them. Get your self a fault code reset gadget off ebay. Well worth the 30 quid.
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
dombanks
Sep 21, 2015 08:38 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
Tank Mike
Sep 10, 2015 07:56 AM
Adam Graham
Sep 6, 2015 06:04 AM
