ABS Light 2wd Cossie
Old Jan 25, 2012 | 12:59 PM
  #41
martysmartie's Avatar
martysmartie
First check the bulb is working, if not you have a power problem to the light I should think.
Martin
Old Jan 25, 2012 | 01:27 PM
  #42
Karl 3dr's Avatar
Karl 3dr
Are you sure its not just something simple like the bulb gone or its fallen out of the back of the clocks?
Old Jan 26, 2012 | 12:59 PM
  #43
Genesis's Avatar
Genesis
Fixed - connector behind dashboard had come loose.
Old Jul 22, 2018 | 05:01 PM
  #44
Cossy Mike's Avatar
Cossy Mike
Hoping to resurrect an old thread,
these are my results, very similar.
Long story short, I removed engine and gearbox, the only thing on the brakes I disturbed was removal of front calipers, which I plugged the pipe's and re-bled on fitting.
At first road test I had the pedal jumping back at me from 10-0mph only. The red light and abs yellow light would come on.
I've fiddled about with the wires and float, the switch seems to work good. The pump primes and clicks of once under pressure.
I have swapped the ABS ECU for a spare, results are the same.
Now the red light (low pressure) no longer comes on when driving but the yellow abs light comes on at random and goes out at random. The pedal has a normal feel, I've covered 128 miles with no further issue.
1. what is the resistance between terminals 11 and 18 (ECU unplugged, ignition off) ? 004
2. what is the resistance between terminals 11 and 1 (ECU unplugged, ignition off) ? 0
3. what is the resistance between terminals 11 and 15 (ECU unplugged, ignition off) ? 005
4. what is the resistance between terminals 11 and 16 (ECU unplugged, ignition off) ? 003
5. what is the resistance between terminals 11 and 17 (ECU unplugged, ignition off) ? 006
6. what is the resistance between terminals 11 and 18 (ECU unplugged, ignition off) ? 003
7. what is the resistance between terminals 11 and 33 (ECU unplugged, ignition off) ? 003
8. what is the resistance between terminals 11 and 34 (ECU unplugged, ignition off) ? 003
9. what is the resistance between terminal 9 and earth (ECU unplugged, ignition off) ? 1
10. what is the resistance between terminal 10 and earth (ECU unplugged, ignition off) ? 1
11. what is the resistance between terminals 1 and 3 (ECU unplugged, ignition off) ? 000
12. what is the resistance between terminals 1 and 20 (ECU unplugged, ignition off) ? 000
13. what is the resistance between terminals 1 and 8 (ECU unplugged, ignition off) ? 068
14. what is the voltage between terminals 1 and 2 (ECU unplugged, ignition on) ? 12.12v
15. with ECU unplugged and ignition off, temporarily join terminals 2 and 8 with a jumper wire. With ignition on, what is the voltage between terminals 1 and 3 = 12.28v and 1 and 20 = 12.17v
RH rear sensor : Connect ohmmeter between terminals 4 and 1 of ECU. Infinity
LH rear sensor : Connect ohmmeter between terminals 6 and 1 of ECU. Infinity
RH front sensor : Connect ohmmeter between terminals 7 and 1 of ECU. Infinity
LH front sensor : Connect ohmmeter between terminals 5 and 1 of ECU. Infinity
All sensors show 1050 - 1100ohms resistance
original
Apr 28, 2026 05:20 PM
FlashRS
13
Aug 31, 2015 06:02 PM
rdvil
Aug 15, 2015 12:11 PM
RsS2daz
Aug 14, 2015 05:26 AM
Old ford
Jul 31, 2015 06:50 AM
