cosworth managment wiring...
what size/amp cable do i need for the battery live, battery earth, ignition, tacho and fuel pump feed?
any help would be appreciated
www.vehicleproducts.co.uk
is a good place to get the stuff you need, and has recommended sizes in the listings for various functions.
A useful formula is V/IxR, that is basically the easy equation to work out how many amps the draw is, take the wattage, say 120watts, divide by the volts 12 = amps(10).
Try to use thinwall wire where you can it is much much tougher insulation, if you get stuck pm me.
JK12
33
Apr 26, 2021 12:09 PM
Nov 3, 2015 04:08 PM
