YB Coil on Plug / Direct Fire Coils
Old Nov 12, 2010 | 07:45 PM
Slyman's Avatar
Slyman
Default YB Coil on Plug / Direct Fire Coils
I have been looking at the choices for coil on plugs that are starting to creep in on some YB engines.
Can you run wasted spark with DFC (Direct Fire Coils)?
Do they produce a more powerful spark than the Zetec coils?
I have found these Toyota Denso coils are the right fit-
Old Nov 12, 2010 | 07:52 PM
mhs's Avatar
mhs
with which ECU ?
Old Nov 12, 2010 | 08:05 PM
Slyman's Avatar
Slyman
Originally Posted by mhs
with which ECU ?
Looking to use either MoTec or DTA (S60)
Old Nov 12, 2010 | 08:08 PM
mhs's Avatar
mhs
MegaSquirtII low cost
Old Nov 12, 2010 | 08:22 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
id hazard a guess both them ecus will run them coils
in fact there the exact same coils i plan to use on my new engine ,
already had the rocker cover modifyed to suit ,
Old Nov 12, 2010 | 08:30 PM
Slyman's Avatar
Slyman
I have heard many different opinions regarding the use of these coils on the YB, Im guessing they supply a more powerful spark at high revs? these were used on a Toyota Yaris 1.5 litre VVT engine. Who recommended them to you and what is your rough spec??
Old Nov 12, 2010 | 08:34 PM
Mark Shead's Avatar
Mark Shead
I would run them as 1 coil per cyl wasted spark can make them run hotter if they req long dwell times, I perfer the Chevy LS1 coils with leads.
Mark
Old Nov 12, 2010 | 10:33 PM
Slyman's Avatar
Slyman
Mark
Any pictures of that setup Mark?
So you would not run wasted spark with the individual coils?
Old Nov 13, 2010 | 07:56 AM
Mark Shead's Avatar
Mark Shead
I dont see the point of wasted with a ecu that can run 4 ign out puts as it costs no more. I wll take pict today.
Mark
Old Nov 13, 2010 | 08:04 AM
A lot of work and money for no gain on most engines though, maybe better spending money elsewhere, but your money if you want to double the amount of bits that can, and do go wrong over a normal coilpack.
I always follow the KISS policy, only way to be imo.
Old Nov 14, 2010 | 06:09 PM
Slyman's Avatar
Slyman
I would love to know what these ones are, fitted on a rather sexy Prep 'n' Play YB-
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
