zetec s / rs turbo
zetec s / rs turbo
well iv got my zetec s fiesta as a project. looking into engine conversions as i miss my rs turbo a great deal. the wiring bit is the only thing that blows my mind away tho.
i was thinking if i was to fit the fiesta rs turbo lump on a diesel courier van g-box so the mecanicals are done. the wiring side i was thinking that instead of cutting looms up to make a super loom, i could just transfer a complete fiesta rs turbo loom (or xr2i) into the car..... would this work?
cheers
cheers
so in theory swapping the whole car loom would be easier.... its a on going project so ill have time to re loom the whole car... dont want to start cutting 2 looms into one
cheers mate
cheers mate
yeh cheers mate, looks like to keep things easy for my and whom ever i get to set up the car the frst complete set up will be better. or ill end up with some hybrid super shit loom that does nothing lol
cheers mate
cheers mate
easyer than that mate, you can cut back you engine bay loom (starts at the fuse box at the back right of the engine bay, runs lights ect aswell.) cut all the engine sensors out bar the gearbox sensors and fan switchs and the coolent sensor (this tells the ecu what to display on your clocks)
then its 7 wires to put your frst loom in,
standard pumps are pretty good tbh so ok to start with.
you have to retain the stadrd zetec s ecu, it runs the lights and dash , heater ect, all runs through it and its fuse box,
you can how ever trim the loom back loosing most of the engine baysensors,
then lay the frst loom over the top, just popping the ecu inthe glove box then connect up the appropriate 7 wires
so 2 ecus
so 2 ecus
Cheers bud. I jus remembered about the rs turbo rear set up you wanted...when i went up to that lock up it had be broken into so i forgot as po po had to sort things out before i had access again. Still need it?
i was going to use cvh just because i have the block ready to use for mocking up... i do like the idea of a zetec turbo but i like cvh as its something i have worked on time and time again....hmmm not sure:S would it still run fiesta turbo management? or would it be worth putting standalone on?
if you go megasquirt its easy, as you can still use the rs turbo bay loom, and all its standard sensors inlet ect.,
would make for a nice fun car, and can use standard rs turbo rad and intercooler and exhaust, so makes for quite a simple swap;.
use a sport ka gearbox, better ratios.
i can supply you with a modified lsd for that to
Rods and pistons ideally but decomposition and rod bolts would do. Oil cooler kit, drill sump (use a puma one as holds extra litre) puma inlet (metal) megasquirt and some bigger injectors (2.3 duratec ones) and a 1.6 focus zorts manifold to make into turbo manifold (there stainless) and a t2 or t25
So a bit of outlay but could all be done on budget apart from managment.
Since you said zetec tturbo its really making me think....200bhp and potential for plenty more.. Ill be happy with 200 just for a toy. That way the zs box. Ka bellhousing and modified diff will be fine. No need to change gear box. Or for 200 will a cvh be good?
If u go cvh or zetec u will need a ka box for the bell housing. I blew 3 gear boxs on my zs lol the standard diff is weak hence wanting the LSD. Cvh will do 200 yes just questionable reliability were as a fresh built zetec will cost a grand but only need about 10 psi to do 200..
Will the diff you said you have do the job? Is that a complete build... Turbo and everything?? really thinkin zetec turbo for that price zs box will survive a short life then lol
Cheers... You do know your stuff..... Im now not sure what way to go main thing i want is turbo power but budget as i dont have mega money spare it
Turbocharging Technician
