Fuel pump mk3 fiesta
Old Nov 5, 2010 | 09:10 AM
fiestafionn's Avatar
fiestafionn
Default Fuel pump mk3 fiesta
I had a cut out problem and thought it was to do with fuel. So i dropped the tank and tested the pump it was fine. I then checked spark again and it was weak. So I then went and got a csp sensor and replaced it and a plug lead because it was very faulty. I went back and put everthing together the day before yesterday and I had no fuel coming to the cfi unit. So I took off the tank and tested the pump it wasn't working. There is a fuel pump restart switch and it has the security with the key and the red light in the dash. So where do I go from here any q's or a's welcome.
YODI
Aug 30, 2015 01:12 PM
ekjim
Aug 27, 2015 05:20 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
dlwarrior
Aug 5, 2015 10:19 AM
