Focus ST 06 :-(
Old Nov 1, 2010 | 11:01 AM
wigan_sinker's Avatar
wigan_sinker
Default Focus ST 06 :-(
I have been having a little bit of bother with my 06 ST.
I recently fitted a dump valve to the car, it worked fine but i discovered a hole in one of the pipes coming off the intercooler, so i bought some samco and replaced all of the turbo hoses.
After fitting i went to start my car and it seem'd like the battery had died. so i put it on a jumper pack and got it started. drove round for an hour to give the battery a charge. got the car home, quick shower, jumped back in my car, turned the key and nothing, just got that annoying clicking sound. tried to jump it off my mums car and still nothing.
My ESP system fault light came on on the way home.
I'm thinking the battery could be shaged, but after reading a few things on here, i think it could be the alternator. If it is the alternator I could get it replaced on warranty as i took out the extended warranty. but with the car now fitted with samco, dump valve and an air filter. do you think this would void the warranty?
Thank you in advance
Old Nov 1, 2010 | 05:18 PM
wigan_sinker
Unhappy
Can nobody help
Cars sat here on the drive and i've not a clue weather to take it back to fords or pay someone. it might not even be the alternator, could just be a flat battery.
Could just do with abit of advise.
I just feel like
Had nothing but trouble with this car, first few weeks of having it i had the driveshaft, CV joint and wheel bearing go.
Then a few months later the oil separator diaphragm thingy went.
Now this lol
Any advise would be top
Old Nov 11, 2010 | 09:38 AM
wigan_sinker
Bump
Can nobody help? checked the battery and all is fine, also checked the alternator and that fine.
I have been told that it could be a bad earth. but where from?
Old Nov 11, 2010 | 10:46 AM
martysmartie's Avatar
martysmartie
How have you deemed the alternator to be working? Could well be the alternator seen as they are common problems with these. The fact it starts when assisted with a jump pack shows the battery to be in a discharged state.
Jump starting will not help if the battery is that discharged, so charge the battery.
Yes as you have modified the car that will void the warranty.
Martin
Old Nov 11, 2010 | 10:50 AM
wigan_sinker
I got it started and put a multi meter across the battery and it came up with 13.8v. which i have been told means the alternator is working. I have fully charge the battery and tested the cells and they are all good.
Old Nov 11, 2010 | 11:07 AM
martysmartie
That is fair enough, it's just by your last post you said you hadn't actually got the car started yet so wasn't sure how you knew.
So how are you getting the car started now then?
Martin
Old Nov 11, 2010 | 11:21 AM
wigan_sinker
i jumped it off a friends van, only got it started once since it broke. i've been told by a friend who has had about 6 ST's, his did the same and its the earth coming off the battery apparently so gunna try that
Old Nov 11, 2010 | 11:42 AM
martysmartie
Yep that would do it, let us know how you get on.
Martin
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
