reverse light working opposite way round cossie???
Old Oct 31, 2010 | 06:58 PM
bigturbokev's Avatar
bigturbokev
Default reverse light working opposite way round cossie???
hi guys im proper stumped, just wired up my reverse light swich on my cossie bm, the way i have it wired up is = out of reverse light fuse --to 2wd t5 reverse light swich -- to rear reverse light bulb the to earth. i was under the impession that the swicth was a push to make, but what is actually happening is that the light stays on all the time but when i put it in reverse the light goes out, making it to seem like a break to make switch like the one for the brake light, and i though if the switch was faulty it wud either no work or be on all the time. and i have tested it out of the box and the same is happening.??????????????????????????
Old Nov 1, 2010 | 05:29 PM
bigturbokev
anyone??
Old Nov 2, 2010 | 08:44 AM
Wrong switch, if stuck finding a switch could always use a changeover relay to make the circuit work the way you need, till you find a correct switch.
Old Nov 2, 2010 | 08:20 PM
bigturbokev
sweet, i thought it must be something wrong with the switch but never heard of one work the opposite way around though
JoeyBoyden
Jan 4, 2024 02:36 PM
Karl 3dr
102
Oct 14, 2016 08:17 PM
RsS2daz
Aug 14, 2015 05:26 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
