Scorpion exhaust
Ok peeps. If have been building my saff back up (it was a rolling shell when I bought it). I got the exhaust system fitted today (scorpion) but the back box hangers are miles off. I have the tailpipe at the right position, but to get it there, i have had to push the hanger attached to the box all the way through the rubber( see first two pictures). I cant line the two hangers up as it hits the bumper. Any ideas???
Something is clearly amiss, is the middle section far too low ?, ordinarily you can only just get a finger between the pipe and the bumper above it, and I don't recall a big gap at the side of the box, maybe the box was not from a cossie ?, you could always cut and re weld the bracket.
