Do I need the oil modine? 2wd track saff
Testing the future
the modine oil/water heat exchanger works in 2 ways. firstly it helps to get the oil up to working temperature quicker by using the water (that heats relatively quickly) to heat it, but then once the oil is tending to get hotter than the water it will work the other way around and use the water to cool the oil (as heat transfer can only take place from a hot thing to a cooler thing).
i would use it, unless it proves to be inadequate at keeping oil temps down in which case, as alan says you should be using a air/oil heat exchanger.
personally, if you are considering an air/oil, i would add it to the water/oil one, as an air/water one is no use if the car's not moving (for example in the paddock during idle cool down)
FlashRS
13
31-08-2015 06:02 PM
mrmann
20-08-2015 11:24 PM
Roosie
09-08-2015 07:37 AM
