Incontinent Cosworth
Old Oct 25, 2010 | 09:21 AM
Jase-G22TMJ's Avatar
Jase-G22TMJ
Cosworth, enough said!
Cool Incontinent Cosworth
Heeeeeeeeelllllllllpppppp
Has anyone ever come across this before, you drive your Cossie day in day out no worries, no signs of water leaks or head gasket problems, you park it in the garage after a day out then 1 2 3 4 5 hours go by and all of a sudden it starts dropping its water from somewhere around the engine area but no sign of from where
Last night I went out hour after hour and nothing, then when she was stone cold after about 5 hours of not running out comes its water but never when im watching and as stupid as it sounds no sign of from where!
Any ideas guys
Cheers Jase
Old Oct 25, 2010 | 05:09 PM
Cossy Mike's Avatar
Cossy Mike
Mine done this when I first got it. It turn out to be the radiator.
Someone had put rad weld in it and when it cooled down and stood for a bit it leaked out.
Then when running and got warm it sealed up again.
Check your radiator and your water pump at the front, thats were my money is
Old Oct 25, 2010 | 06:11 PM
Jase-G22TMJ
Im trying mate but as odd as it sounds theres no drips anywhere, gotta be coming from the motor given the position on the floor, maybe water pump...... or possibly thermo gasket god knows
Old Oct 26, 2010 | 06:32 AM
cospower's Avatar
cospower
hi jase, it could be a water pump by sound of it. Have you got compreesed air available? Put a piece of cloth around the expansion tap (obviously remove the tap) and try to blow a bit of air in the tank, holding the cloth around the exit. Hopefully you'll be able to see were it is coming from
Old Oct 26, 2010 | 09:04 AM
Jase-G22TMJ
Im gonna try that next, its got to be an expansion and contraction thing as it only does it when the motor is stone cold this morning ive put some clean dry card under it in the hope of locating a drip with any luck I should have a general area to search by the time I get home tonight
Jase
Old Oct 26, 2010 | 09:25 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
mine always gets little leaks every now and then to piss me off seems to always be hose clips need re tightening never found a real leak yet just small traces and little drips / puddles on the floor u need to put a presure tester on it when its cold and then leave it till it drips!
Old Oct 26, 2010 | 05:39 PM
Jase-G22TMJ
Right it seems to be the water pump, at least im 99% sure it is but hey what can ya do? So off to the bay I went to get on and sure enough its anywhere between £30 and £135 for new ones, so can anyone throw some light on why I shouldnt buy a brand new one at £30 and not a gen Ford at £100+
As always, your advise is greatly appreciated.
Jase
Old Oct 26, 2010 | 07:53 PM
bigturbokev's Avatar
bigturbokev
well if your stuck theres always pampers dry nites
Old Oct 27, 2010 | 05:45 AM
cospower's Avatar
cospower
Jase I'll go for a Ford original, I've seen imitations go bust after a few years. It's not worth the hasle. Just think about it, if it packs in while you'll nailing the car. Not a very nice thought.
Old Oct 27, 2010 | 02:49 PM
Jase-G22TMJ
Sorted, I got a Valeo pump (purely for speed of delivery) and will on the case as soon as I get home....... fingers crossed
Old Oct 27, 2010 | 07:51 PM
Jase-G22TMJ
Ok so, I got home at 5.30 and set about changing the water pump on my Saff, all is well and ive replaced all the little rubber pipes as well as the jubbly clips (I know its meant to say Jubilee ) and ran her upto temp.......... now the 5 hour cool down time begins, see yall about 1am with an update
Jase
Old Oct 27, 2010 | 09:47 PM
Jase-G22TMJ
Not that anyone else would give a shit but as its been a royal pain in arse ive been out to check a couple of times and so far the Puppy training nappie pad fvckin thingy mabob ive put uner the Saff is dry
Jase
Old Oct 28, 2010 | 09:08 PM
Jase-G22TMJ
FIXED
Old Oct 28, 2010 | 09:14 PM
Cossy Mike's Avatar
Cossy Mike
nice one..
Billy_RS
Sep 13, 2015 04:17 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
