Alternator/Battery light
Old Oct 24, 2010 | 05:43 PM
muppetofdoom's Avatar
muppetofdoom
Default Alternator/Battery light
hi , new to this site and hoping for a little help.
I have recently inherited a 1.8td escort finesse estate, the problem being that the battery light on the dash does not illuminate when i turn the ignition on, but it does flicker on and off while the engine turns over before starting ! the blue wire from the alternator seems fine it goes live about 10v when ignition on so cant see why the light wont come on ?
Any all help appreciated, oh yeh the battery went flat today to.
Old Oct 24, 2010 | 06:35 PM
martysmartie's Avatar
martysmartie
Then the D terminal on the alternator where is connects must be suspect, if you earth that wire as a test it should illuminate bulb as you have power there.
Also to test Alt if you rev to around 4K this will start the charge process, may just be a loose connection on the back of the terminal.
Martin
Old Oct 24, 2010 | 06:42 PM
phil_focus's Avatar
phil_focus
10v!!
charge your battery up first!
Steve Escos
Oct 1, 2015 06:57 AM
stevecfrst1
Sep 30, 2015 05:18 AM
deathrider666
Sep 28, 2015 06:12 PM
Sep 28, 2015 10:05 AM
