CVH Timing
Old Oct 22, 2010 | 09:30 AM
andytheracer's Avatar
andytheracer
Default CVH Timing
Does anyone know the correct timing for a 1.6 CVH at around 5000 rpm?
Haynes gives 12 deg for 800 rpm but I also wanted to check it higher up the range.
i've been told 32-34 deg. I also read i think that over about 3000 rpm it stays pretty constant, is this right?
Any advice appreciated (destroyed 3 pistons already due to incorrect timing!!)
Old Oct 22, 2010 | 09:36 AM
chaffe's Avatar
chaffe
Turbocharging Technician
I take it your on about NA ignition timing? And at what AFR and engine tune? compression ratio etc, all these things will come into effect.
Old Oct 22, 2010 | 09:40 AM
andytheracer
Fair point. the engine can be considered standard. AFR around 0.9 (slightly rich hopefully!)
Old Oct 22, 2010 | 10:02 AM
chaffe's Avatar
chaffe
.9 lambda? what does that equate to in Air fuel ratio? i would of said 30 ish degrees btdc is not far wrong, i take it you can hear no audiable pinking?
Old Oct 22, 2010 | 10:14 AM
andytheracer
No i couldn't hear anything in the past. 0.9 is about 13.3 afr. sounds like low 30s is about right
Old Oct 25, 2010 | 06:51 PM
chaffe's Avatar
chaffe
i see, every engine is different mate, depends on the base ignition, and how the flywheel was cast/machined for the trigger
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
hopper350
Sep 4, 2015 12:53 AM
s1turboman
Aug 29, 2015 04:27 PM
Ben26
Aug 27, 2015 08:56 PM
