Ford 2.0 SOHC Intake Manifold
Old Oct 22, 2010 | 03:38 AM
jdp530's Avatar
jdp530
Default Ford 2.0 SOHC Intake Manifold
I am re-building a 1988 engine that uses a Weber 32/36 DGV. I noticed that the ports on the intake manifold are apprx 5 mm smaller in diameter than port openings on the head.
Would there be any performance loss or gain if intake ports are matched to the head? Or should I leave the manifold alone? Do the smaller intake runners/ports have a higher intake velocity producing more low-end power? Thanks,
Old Oct 22, 2010 | 10:36 AM
If it's a std engine you're not going to notice any difference from port matching imo.
Escortdriver1
Aug 5, 2015 12:45 PM
