new t34 shaft?? pics inside
Old Oct 20, 2010 | 04:39 PM
dearing5's Avatar
dearing5
Default new t34 shaft?? pics inside
i bought a garrett external gate t34 57trim turbo and there was loads of play in the shaft...
i have stripped it down and looks like the shaft is worn?? he has a really small oil restrictor on there, around 1.5 - 2mm!! has it been starved of oil?? its a journal bearing.
can i get a new shaft for it? what happens about balancing?
cheers
Old Oct 20, 2010 | 07:57 PM
It will need rebalancing best bet is to pop in the post to a turbo rebuilder with the correct kit.
Old Oct 20, 2010 | 08:44 PM
dearing5's Avatar
dearing5
a guy sells them on ebay saying ready balanced?? he sells loads of turbo parts etc
cant i rebuild it myself an then send it off? will the bearings be mashed to?
Old Oct 21, 2010 | 10:30 AM
dearing5's Avatar
dearing5
can i buy a new shaft?? anyone
Old Oct 21, 2010 | 10:37 AM
chaffe's Avatar
chaffe
Turbocharging Technician
if it is balanced before then it will be balanced after. your wheels dont need balancing every time you take them off. As long as you mark the nut, shaft and compressor housing, so that you can assemble it in the exact same place as it was before. Measure the shaft and see if its worn. Turbos are balanced outside the cartridge, dissassembled, then re-built inside the cartridge. so therefore why cant you take it out and re-asemble it yourself? It just needs to be kept inline thats all.
Old Oct 21, 2010 | 10:40 AM
chaffe's Avatar
chaffe
as long as the shaft is not too badly worn/scored and the wheels are not damaged, then you will get away with a re-build kit, providing you marked the turbo up before taking it appart! otherwise there will be no knowing the orientaton it should go back together. If your buying a new shaft it must come paired with a compressor wheel and nut i would think?
Old Oct 21, 2010 | 10:52 AM
chaffe's Avatar
chaffe
Old Oct 21, 2010 | 01:29 PM
dearing5's Avatar
dearing5
i would of marked it but i accidently moved the wheel while holding the other end so it moved!! AH
i'll try post a pic of the shaft but it was wobbling round in the cartridge before i stripped it. surely if its balanced out side the housing why would it matter where it goes?? surely if the wheels are balanced.
edit
the shaft looks ok but i will measure it, maybe the bearings are worn? look scored....would a smal restrictor cause premature bearing wear?
Old Oct 21, 2010 | 01:44 PM
chaffe's Avatar
chaffe
its balanced as a unit, similar to the way you can balance a crank, flyweel and clutch together, or the inside and outside of a wheel. So i always ensure they go together in the orentation the come appart. Ive done one before without lining them up, cos i did the exact thing you did first time round! put it back together, but you could clearly hear the turbo vibrating as it spooled at a set speed, and it smoked! Done several since with no hassle though.
Old Oct 21, 2010 | 05:04 PM
dearing5's Avatar
dearing5
ah ok, i got no worries getting it balanced! should of took more care but i thought the shaft had had it so...
is it likely the bearings have worn more?? the shaft is thinner in area's but i take it this is due to the balance??
Old Oct 21, 2010 | 07:09 PM
dearing5's Avatar
dearing5
pics..
there is daylight between the shaft and bearing, also the bearing wobbles on the shaft. before i stripped it, the wheels were nearly touching the housings!
checking the compressor wheel and housing, it has just touched causing a mark on the housing. is this bad?? basicly looks like a light scratch, the wheel looks fine just slightly worn the outer fins where it touched.
can i get away with it?? there not bent or broke.
Old Oct 22, 2010 | 08:20 PM
dearing5's Avatar
dearing5
ok found out one bearing is worn or both but one is worn more??
Old Oct 23, 2010 | 10:10 AM
chaffe's Avatar
chaffe
At a minimum you wil have to polish the shaft in a lathe, then get two new bearings and a thrust washer, but these are supplied in a re build kit, you will need to replace the cast iron seals too mate
Old Oct 23, 2010 | 10:43 AM
dearing5's Avatar
dearing5
ah ok, are the iron seals the little piston ring type things on each end??
Old Oct 25, 2010 | 06:16 PM
chaffe's Avatar
chaffe
Yeah mate, that's the ones
Old Oct 26, 2010 | 11:37 AM
dearing5's Avatar
dearing5
wilky is doing the work seems a good chap.
155lee
Sep 6, 2016 11:10 AM
Rsmat
63
Sep 25, 2015 12:11 PM
28
Sep 8, 2015 07:10 PM
rsstav
Sep 7, 2015 04:43 AM
hopper350
Sep 4, 2015 12:53 AM
